Results 1 to 2 of 2
Thread: Problem with dispensers & LED lights are not lit?
    Aug 2011
    Default Problem with dispensers & LED lights are not lit?
    Model Number: GS2SHEXML00
    I have the Whirlpool Gold Conquest side by side and today the water filtration system has LED lights that are always lit green for the water and ice maker but now theres no light. the filter light was yellow. and the water/ice dispenser does not work anymore, but the ice maker is still working, i did an optics test and it was working fine, i'm not sure what i should check next, should i take a look at the water valves?
    Thats odd, don't think I've run across this type of issue, but it sounds like possibly the dispenser control board may be acting up.
    Here's the data sheet on your electronic dispenser:
    http://adcxns1.whirlpool.com/Service...24-27_UD24.pdf
    Here's the control board#15 for your model, in case you need to order it:
    Control board - Part# W10184871
  1. Ice dispenser problem with GE side by side
    By Jim Smith in forum GE/Hotpoint
    Last Post: July 8th, 2009, 11:38 PM
  2. Replies: 3
    Last Post: September 15th, 2007, 01:27 PM
  3. GE SxS defrost problem..Likely solved, thanks
    By Labonte18 in forum GE/Hotpoint
    Last Post: September 7th, 2007, 02:02 PM
  4. KSRX25FNST01 Diffuser Problem?
    By CajunFrog in forum KitchenAid
    Last Post: August 22nd, 2006, 11:43 AM
  5. Lights Flashing - problem solved
    By MayWork in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 3rd, 2005, 10:53 PM
