Results 1 to 5 of 5
Thread: Problems with ice maker in LG fridge
    Aug 2011
    United States
    Default Problems with ice maker in LG fridge
    Model Number: LRFC25750SW
    Brand: LG
    Hi - I just recently started having problems with my ice maker. The ice maker has started to leak water into the ice drawer and I end up with a solid block of ice. It is still making ice cubes, but they are not separating completely (at all really - they used to) when they drop either. There is a chunk of ice that is now at the top of the cubes that is holding the entire tray's worth together when they are released from the maker.
    I have disconnected the fridge and defrosted the freezer - there was some slight buildup of ice on the coils, but not enough to cause these issues I think. I have priced a new ice maker, they run about 170 bucks. Just want to make sure I'm not overlooking some simple fix or something else to check before buying new parts that may or may not fix the problem.
    Any one else have this issue? Any ideas?
    Aug 2006
    NY
    Don't work much on LG's but it sounds like the water inlet valve is passing water when it shouldn't. So the icemaker overfills/overflows causing the ice clumping.
    Jun 2011
    Danville, California
    It sounds like the water valve is leaking rather than a ice maker problem.. You will need to change it. The part number is 5220JB2010A.
    Good luck.
    Appliance Repair Tech
    LG Authorized Servicer
    Aug 2011
    United States
    Is there a way to determine if it is indeed the water valve? I pulled out the ice maker last night and have not had any water dripping from the inlet tube into the ice drawer. If the valve was bad wouldn't I start to see some leakage?
    Thanks for all your help.
    Jun 2011
    Default Water valve test.
    There is a way to test it. Pull the water valve electrical connections off and run a couple of wires using an old plug to the water valve. With the water still turned on, plug the 120v into the outlet and see if water comes out. If not, the valve is bad. If water does come out, then the icemaker is bad.
    Good luck.
  1. New ice maker - still no ice
    By dkpeppard in forum Sears Kenmore
    Last Post: June 28th, 2011, 08:01 PM
  2. Replies: 13
    Last Post: April 16th, 2011, 07:39 PM
  3. Problems with ice maker
    By Charlie_E in forum Whirlpool/Roper/Estate
    Last Post: April 1st, 2011, 02:50 PM
  4. Superba Ice Maker and Water Dispener
    By Jake in forum KitchenAid
    Last Post: February 3rd, 2009, 10:52 AM
  5. Complete Ice Maker Assembly - For In-Door Ice Models
    By Jake in forum Refrigerators & Freezers
    Last Post: April 29th, 2008, 12:56 AM
Tags for this Thread
