Results 1 to 7 of 7
Thread: No air flow in dryer
    Aug 2011
    Lynnwood
    Default No air flow in dryer
    Model Number: LEW0050PQ3
    My whirlpool dryer - model lew0050pq3 - has no air flow. The drum turns and I have done all the checks for lint blockages and am positive that's not it. I also checked the circuit breaker and checked the power cord’s connection to the dryer for proper voltage and it was good. I opened up the dryer and watched the blower motor when the dryer was running. The blower motor would not turn most of the time, and when it did it only made a couple of rotations – very slowly I might add – and then stopped. Any help?
    Jul 2006
    Sounds like either a bad capacitor or a bad blower motor. I'm not familliar with that model. Maybe someone else will see this and have a better answer for you.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jul 2006
    I think I might be able to help you out. Check this and see if it helps:
    Aug 2011
    Lynnwood
    Thanks. I did the tests and I think the capacitor is fine. The motor had readings, but below what it should be (according to the link you gave me). Do you think that just means the motor's bad and needs to be replaced?
    Jul 2006
    That's what it sounds like. How far off were the readings on the motor?
    Aug 2011
    Lynnwood
    Wait, maybe I was confused. Is the capacitor supposed to go to infinity? It started at about 8 or 9 and was going down towards zero. Maybe that's the problem? The motor readings were around 20-22, and should have been between 26 and 38 (violet to blue wires and violet to red wires) and between 58 and 72 (blue to red wires).
    Jul 2006
    That sounds like the motor for sure. Here is the motor for your machine. The cap you tested is good but it looks like a new motor comes with one.
    Fan Motor 8182472 Order now for same day shipping. 365 day return policy. RepairClinic.com
  1. FIXED: Freezer cold, but Warm fridge side - not cooling? Air flow 101 - HELPFUL INFO!
    By PatrickM in forum Refrigerators & Freezers
    Last Post: November 29th, 2014, 12:30 PM
  2. need help beyond basics - maybe air flow issue?
    By esedlin in forum KitchenAid
    Last Post: May 31st, 2011, 01:20 AM
  3. Whirlpool Dryer Air Flow Issues
    By ddderek in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 21st, 2011, 12:26 PM
  4. Maytag Plus SxS refrigerator side warm then cold then warm
    By PatrickM in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 17th, 2010, 03:07 PM
  5. Correcting air flow to gas dryer
    By rockjock in forum Sears Kenmore
    Last Post: July 14th, 2007, 04:59 PM
