Results 1 to 8 of 8
Thread: Kenmore oven will not maintain temp.
    Jan 2011
    N.W. In.
    Default Kenmore oven will not maintain temp.
    Model Number: 665.75844002
    Age: More than 10 years
    My kenmore oven will not keep temp.When 1st starting it starts fine and goes to desired temp. but when reaching temp. it shuts down will click to try to restart but will not what you have to do is shut it down crack door a little wait about 10-15 minutes depending on oven temp. and then restart if it restarts it will stay going if not you have to try again until you can keep it going.What is the problem?
    Here's another member with a similar issue and the new bake burner igniter fixed his:
    http://www.applianceblog.com/mainfor...nsisently.html
    Read page 2 of that thread.
    Its likely a bad bake burner igniter.
    Here the troubleshooting flow chart:
    www.applianceblog.com/manuals/DSI_manual.pdf
    Here's the bake burner igniter kit for your model you can order here:
    Part#8190618
    Jan 2011
    N.W. In.
    Default oven does not maintain temp.
    Jake I unplugged oven and tried to get an ohm reading of my oven temp. sensor I get nothing could my oven work at all if this is correct reading?Do I have to take temp probe off oven to check I checked mine while still in just unplugged from male peice it goes into .Or do you reall think my problem lies with the bake burner igniter?Just checked it with two differant meters with it out and still get no reading could this be my problem?
    No, you just unplug the range first, then unsnap the little plastic connector that goes to the oven sensor in the back of your range, then do the ohm test from back there on the oven sensor side of that connector.
    Watch this video on how to test it:
    Let us know what it reads.
    Jan 2011
    N.W. In.
    Default oven will not maintain temp.
    I did take the temp. probe out and checked it from the backside and get a reading of OL.Does this mean the probe is bad and could this be my problem?Like I said before if you crack the door wait about 10 minutes the oven will relight and keep the temp. usually.
    Yes, because it should read between 1000-1100 ohms at room temperature.
    Are you sure your meter is working right? I don't I've ever seen one read nothing.
    Here's the one for your model you can order here:
    Manufacturer's Number: 8273340
    Jan 2011
    N.W. In.
    I checked it with 2 different meters both digital one got the OL readout and other just got a 1 on the display was checking from the rear tried numerous times.
    Ok, then you need to order it.
  1. FIXED: Kenmore oven will not maintain temp - starts will not restart
    By haeffnkr in forum Sears Kenmore
    Last Post: June 10th, 2013, 08:13 AM
  2. Replies: 3
    Last Post: December 27th, 2011, 08:52 PM
  3. How often should my oven cycle to maintain temp?
    By Rae418 in forum Frigidaire/Tappan/Electrolux
    Last Post: December 26th, 2010, 11:12 AM
  4. [FIXED] Jenn Air oven won't maintain temperature
    By JRinCalgary in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 23rd, 2008, 04:13 PM
  5. Artic Proflie Can't Maintain Temp
    By andrewge in forum GE/Hotpoint
    Last Post: June 15th, 2007, 10:31 PM
