Results 1 to 2 of 2
Thread: Kenmore dryer good heat but after a few seconds stops automatically
    Aug 2011
    Puerto Rico
    Default Kenmore dryer good heat but after a few seconds stops automatically
    Model Number: 417.88042700
    The dryer seems to work and heat just fine. I run the function test sequence and the only problem appear at turn 4 with the dryness button, the lights on the dryness levels lights should be off and light when I pressed the button but instead the LED's are always on. Its possible that the button is stuck or something. That could be my problem? I would really appreciate your help!
    Yes,
    It sounds like your thermistor or control board is bad.
    Here's the repair manual for the Frigidaire & Kenmore(417) Dryers made after Jan. 2005:
    http://www.applianceblog.com/manuals...Dryer_2005.pdf
    You would need a ohm meter to ohm test the thermistor at room temp. with the dryer unplugged.
    It should read 50K-53K ohms at room temperature, if not, then order the new one and you'll be back in business.
    Here's the one for your model you can order if you need it:
    Manufacturer's Number: 134587700
    If your thermistor tests fine, then its the control board.
    Here's the control board for your model you can order here:
    Manufacturer's Number: 137008010
  1. Kenmore Series 90 Electric Dryer No Heat ?!?
    By parttimerz in forum Sears Kenmore
    Last Post: December 30th, 2012, 01:14 AM
  2. Replies: 12
    Last Post: December 12th, 2011, 12:39 PM
  3. [FIXED] Kenmore gas dryer no heat or timer
    By cozwurth in forum Sears Kenmore
    Last Post: August 5th, 2011, 09:57 PM
  4. FIXED: Kenmore 417.84092500 dryer.. shuts off after few minutes + no heat
    By jephdood in forum Sears Kenmore
    Last Post: May 25th, 2011, 02:24 PM
  5. Kenmore dryer: how long should heat cycle?
    By ffspiel in forum Sears Kenmore
    Last Post: April 8th, 2006, 10:16 AM
