Results 1 to 8 of 8
Thread: Magic Chef Microwave, everything works but it does not heat
    Nov 2009
    Michigan
    Default Magic Chef Microwave, everything works but it does not heat
    Model Number: MCO165UB
    Brand: Magic Chef
    I have an over the range Magic Chef microwave. Everything on it works
    fine, everything sounds normal. It just doesn't heat food.
    Does not even warm anything.
    Where do I start?
    Van
    Jul 2006
    Start by checking the voltage going to the transformer or primary supply voltage. Basically, you're dividing the system into two sections, low voltage side and high voltage side. If the primary supply voltage is correct, the problem will be on the high side. If there is no voltage or the incorrect voltage, the problem will be on the low side. More often than not the problem usually ends up being a bad micro switch for the door.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2009
    Michigan
    Can you give me a little info on how to check the voltage?
    Do I have to remove the microwave from the wall?
    Jul 2006
    No, you can check it in place but you'll need to recheck your model number for me. Nothing comes up for that one.
    Nov 2009
    Michigan
    I rechecked the model # MCO165UB
    Jul 2006
    Unplug the microwave and then remove the top vent so you can access the screw on the top of the control panel. Remove the screw and the control panel will come off. All of the major components can be accessed from there. You'll need a volt/ohm meter to do any testing.
    Nov 2009
    Michigan
    One of the door micro switches was bad. $12 later and its working again.
    Van
    Jul 2006
    Cool!! Good job!
  1. Magic Chef Gas Wall Oven won't heat
    By mndzab in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 3rd, 2011, 08:39 PM
  2. Magic Chef takes forever to pre-heat
    By Tyrant in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 25th, 2010, 10:27 PM
  3. Magic Chef Microwave MVP III vm11eb-8p
    By splicedude in forum Maytag/Jenn-Air/Magic Chef
    Last Post: November 27th, 2009, 05:07 PM
  4. magic chef microwave VM11EB-8P
    Last Post: April 1st, 2008, 12:59 PM
  5. Magic Chef Microwave Problems
    By Eagle Spirit in forum Maytag/Jenn-Air/Magic Chef
    Last Post: December 18th, 2006, 04:30 PM
