Results 1 to 10 of 11
Thread: 80 Series making grinding noise and won't agitate (but I'm agitated).
    Oct 2009
    Tampa, FL
    Default FIXED: 80 Series making grinding noise and won't agitate (but I'm agitated).
    Model Number: 110.24862300
    Out of nowhere... grind away...
    Drug out in the garage, drained the water. Noticed the amount of oil/grease everywhere, but I think it's always been that way? Even on the lower sides of the the washer.
    Nonetheless, this part barely turns and there is a grinding noise... any thoughts?
    Oct 2009
    Tampa, FL
    I've had an "aha" moment! After educating myself with this model, I went for it by removing the motor/transmission and decoupling... lo and behold:
    Oct 2009
    Tampa, FL
    And a gotcha... when I was moving the machine temporarily back into the laundry room to reclaim the garage space while I await my part, this piece tumbled out when I sat it upright... I've scoured over diagrams and can't seem to find it... anyone have a clue? I'm sure after about 2 hours of piece by piece inspection I *might* be able to find its home but I'd rather ask for help than get overly frustrated! Thanks!
    Yup,
    You need a new motor coupling.
    You can order it here:
    Manufacturer part number 285753A is RepairClinic item number 1195967
    Here's the video to change it:
    That pin is your shipping pin, you don't need it anymore once the washer is delivered at your house when its new.
    Oct 2009
    Tampa, FL
    Thanks, Jake, I appreciate the reply!
    Oct 2009
    Tampa, FL
    Have the part in hand and will install tonight!
    Ok, sounds good.
    Oct 2009
    Tampa, FL
    So far so good, all tests well, first load in!
    Oct 2009
    Tampa, FL
    That was it: FIXED.
    Excellent, good job.
  1. Maytag dishwasher making grinding noise
    By rmather in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 10th, 2013, 12:14 PM
  2. Replies: 39
    Last Post: July 29th, 2010, 01:43 AM
  3. fridge making a loud grinding noise
    By crm in forum Frigidaire/Electrolux
    Last Post: October 24th, 2006, 12:40 PM
  4. Replies: 4
    Last Post: April 3rd, 2006, 02:05 PM
  5. Replies: 5
    Last Post: November 22nd, 2005, 05:09 PM
