Results 1 to 10 of 17
Thread: Dryer drum not balanced - rubbing on metal panel in one spot
    Aug 2011
    Massachusetts, USA
    Default Dryer drum not balanced - rubbing on metal panel in one spot
    Model Number: DPSE810
    Brand: GE
    My GE (DPSE810) electrical dryer was making a horrible, metallic scraping sound. I took off the front and top panels, turned the drum with my hand and quickly found the source of the noise: The drum was scraping against the small, front flap of the left side body panel. There is some give and if I push the drum towards the back while I turn it - no noise.
    So is there a part that keeps the drum in place - so that it doesn't scrape against the panel? Or is it just a question of obtaining a level balance on the floor?
    Someone I asked (who has not seen the dryer) said I should replace the rear drum bearing. But that sounds like the answer to a mechanical problem. THis is DEFINITELY simply an issue of the drum rubbing/grinding on one place in the front.
    Would a new rear drum bearing prevent that? Can you tell me what the rear drum bearing actually does? And would it be evident the part needed replacing if i uncovered it - would it be worn down? (I haven't removed the drum yet)
    The four plastic drum slides are only very slightly worn. I can replace them, obviously, but I find it very hard to believe those thin little strips are responsible for keeping the drum balanced as it spin (but I'm really an amateur here.)
    Any advice would be greatly appreciated.
    Thank you SO, SO much for your time and expertise!
    Jul 2006
    Quote Originally Posted by roughpix View Post
    You shouldn't be able to push the drum back. The person you asked is correct. Here is your part
    Drum Bearing Kit WE25M40 Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Aug 2011
    Massachusetts, USA
    Thank you so much! That certainly answers that.
    Jul 2006
    You're so welcome!
    Aug 2011
    Massachusetts, USA
    Default Drum Bearing Kit
    So, I've removed the old drum bearing and I have to say -- it looks exactly like the new one. There is no damage, and barely any wear that I can see. But that's what people say my problem is, so... Before I put the new one on, can someone tell me: Do I need to tighten the large bolt on it so it isn't able to slide at all? (Hope that question makes sense - in both the old, and the new piece, there is much play on the piece that kinda looks like a top (Don't know exactly what you call it)).
    Any help?
    Aug 2011
    Massachusetts, USA
ID:	2647Click image for larger version.
    These two photos show what I mean - there's a lot of play there. Am I supposed to put it on like this, or tighten it down first?
    Aug 2011
    Massachusetts, USA
    Default Ugh - new drum bearing in, still scraping...
    So now, I've put the new drum bearing in and it the dryer was fine... for awhile. Now, it's scraping again. If I lift up the front of the dryer, it stops (because the drum slides to the back
    and stops scraping against the front).
    So I'm guessing I was supposed to tighten the large nut on the bearing so it isn't able to slide at all? (I tried on the old piece after I put the new one in, but couldn't get it budge it - even using a serious heavy duty vice)
    Or maybe this is just a question of setting the balance on the floor a little askew, so that the front is higher than the back?
    Help?! Please?
    Jul 2006
    If all it takes is raising the front legs to make it stop rubbing, do that first.
    Jun 2012
    PA
    Help?! Please?
    Wow, same exact problem on the same model. I purchased the drum bearing kit mentioned by Rick but it didn't resolve the issue. Any other advice? Many thanks!
    Jul 2006
  1. [FIXED] Dryer drum metal on metal
    By BigT67 in forum Sears Kenmore
    Last Post: October 31st, 2010, 12:41 AM
  2. Maytag PAV5157aww metal to metal squeak at end of spin cycle
    By crabtree in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 19th, 2007, 01:20 AM
  3. Rust spot on tub/drum - ruining clothes
    By michelleann in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 9th, 2006, 07:04 AM
  4. Kenmore dryer drum rubbing noise
    By mattj in forum Sears Kenmore
    Last Post: October 1st, 2005, 01:19 AM
  5. Kenmore Dryer - Rubbing Noise
    By ger1 in forum Sears Kenmore
    Last Post: August 1st, 2005, 11:32 AM
