Results 1 to 2 of 2
Thread: Kenmore front load washer door switch
    Aug 2011
    Default Kenmore front load washer door switch
    Model Number: 417.44052401
    I browsed your forums and was able to print/run the kenmore washer diagnostics on my ailing washer. Im almost convinced it IS the door switch, but want to confirm one nagging question. Origonal issue, washer will not spin, will agitate without issue, but not spin. ran the diagnostics and it WILL spin full speed with or without a load, I had to spin out the failed load. Now, im almost convinced it is the door switch, but when it spins in diagnostics, does it bypass/ignore the door switch state? Also, the diagnostics code i got was a 4 full flash/beep and 3 silent start light flashes.
    Here's the repair manual for your model:
    3.0 cu.ft. Horizontal Axis Front-Load Washer (Good & Better Models):
    You can run the diagnostics and see if an error code comes up, Read Page 10. You have the "GOOD" model(non-digital display). So an error code will be read with the flashing lights you count.
    Here's how to test the door lock latch switch assembly:
    Remove the door lock assembly and
    measure the resistance of the PTC.
    The PTC is the wax motor on the door lock assembly. You will need an ohm meter to test that.
    If it reads 1500 ohms, then its fine, and the problem would be the control board.
    Here's the door latch/lock assembly for your model you can order:
    Manufacturer part number 131763202 is RepairClinic item number 1531974
    Watch this video to access/change it:
  1. FIXED: Frigidaire/Kenmore 417. front load door catches
    By Mad Mac in forum Frigidaire/Electrolux
    Last Post: November 29th, 2012, 01:09 PM
  2. Replies: 3
    Last Post: April 18th, 2011, 04:26 PM
  3. [FIXED] Kenmore 417 Front Load- Door Won't Latch
    By 5girls in forum Sears Kenmore
    Last Post: March 28th, 2011, 12:24 PM
  4. Frigidaire Front Load Washer / FWT445GES2 door lock
    By Dynusia in forum Frigidaire/Electrolux
    Last Post: October 17th, 2005, 04:01 PM
  5. Kenmore HE3 Front Load Washer
    By Elvisf16 in forum Sears Kenmore
    Last Post: July 26th, 2005, 07:14 PM
