Results 1 to 2 of 2
Thread: simple gas stove question
    Sep 2011
    Default simple gas stove question
    Model Number: 970
    I want to inspect/replace one of the sparkers on a burner on my gas stove. How do I lift the stove top? Grilles, caps and diffusers just lift off, how is the stove top attached? Is it just by snaps (pull up) or are there screws I can't see? I've tugged gently, don't want to pull too hard if that's not right.
    Kenmore gas stove model 970
    Sep 2011
    I discovered the answer thru trial. To answer my own question: There are two clips at the front corners of the stove top; slide a knife under the top (inbetween the top and the front knob panel) to push each clip in, which releases the front of the top (lift slightly). Then, remove all burner screws (nine) so that the burners do not lift up with the stove top. Then lift the top about an inch and slide it forward to disengage the rear grabs, and lift it off. The burners may have to be poked down to prevent them wanting to move or come up with the top cover.
  1. Replacing a "simple" door latch
    By willkyndig in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 11th, 2011, 12:33 AM
  2. Frigidaire Crown Series Electrical stove - repair vs buy new stove
    By ramiror in forum Frigidaire/Tappan/Electrolux
    Last Post: July 7th, 2010, 01:52 AM
  3. FRS26ZNH - Ice Container Rust. Might be a simple Question
    By skylightmissing in forum Frigidaire/Electrolux
    Last Post: June 12th, 2009, 10:20 AM
  4. Really simple question
    By rtay0118 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 13th, 2007, 01:20 AM
  5. Simple Kenmore range: burners won't turn on, light does
    By thinkmassive in forum Sears Kenmore
    Last Post: August 3rd, 2007, 11:46 AM
