Results 1 to 6 of 6
Thread: buzzing/humming sound
    Mar 2011
    austin
    Default buzzing/humming sound
    Model Number: js42seddbda
    Brand: Jenn-Air
    My refrigerator has been making a buzzing/humming sound for about 30 minutes. It stops completely whenever I open a ref or freezer door but then starts up again a few seconds later. I do not hear any clicking sound. On the advice of this board, I had my sealed unit replaced about 6 months ago--it was very expensive, so I am obviously frustrated at my new problem. Any idea?
    quick update: the noise appears to be coming from the area where the ice maker is. But the ice maker is off and has been off for months. There is some frost build up on some of the shelves. The fan is running a lot and the top panel of the machine is hot. I turned everything off--not sure if there was right but I don't want to do more damage.
    Sounds like the evaporator fan motor is making that noise, thats basically right were its at behind the ice maker.
    Mar 2011
    austin
    Thanks Jake--I ended up turning it on before bedtime last night. I woke up to no more noise and a 38-0 read on temp. Do you think there is a problem with the fan or was that extended peiord normal?
    Its really hard to say unless it contines to do it enough to pinpoint it.
    Jan 2011
    Texas
    Sounds like we've got the same problem although I'm further along with it. The evaporator pan is freezing over and water is dripping onto the fan area and freezing causing noise. This will eventually come down into the entire freezer area and build up. I've had several things replaced including the entire pan and still it has not solved this. Can someone help us out on this? Thanks!
    Here is a link to another thread I posted on about this:
    http://www.applianceblog.com/mainfor...fan-noise.html
    Mar 2011
    austin
    After the initial day of the buzzing noise, everything seems to be working great now. So I wonder if this was just temporary or if there is more to come later.
  1. Dryer makes humming sound.
    By testman in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 3rd, 2011, 11:50 PM
  2. Freezer making loud humming sound
    By raf28arts in forum Frigidaire/Electrolux
    Last Post: May 3rd, 2011, 12:27 PM
  3. always buzzing (humming) sound of Kenmore 596.76502500
    By byungdonjang in forum Sears Kenmore
    Last Post: March 14th, 2011, 01:23 AM
  4. Neptune MAH4000 humming sound before shut down
    By blueLEDs in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 12th, 2010, 09:15 PM
  5. Kenmore 66515882000 grinding/humming sound
    By spotted dogs in forum Sears Kenmore
    Last Post: March 15th, 2006, 05:32 PM
