Results 1 to 6 of 6
Thread: Ice maker, makes ice but it does not dispense ice
    Oct 2011
    Oakdale, MN
    Default Ice maker, makes ice but it does not dispense ice
    Model Number: GLHS68EJSB0
    Brand: Frigidaire
    Our ice maker does make ice, but nothing happens when you activate the dispense lever.
    Ok, read this thread here:
    http://www.applianceblog.com/mainfor...tml#post136215
    Your model uses the exact same actuator lever and microswitch. In fact all the parts in the diagram are identical to your model.
    Oct 2011
    Oakdale, MN
    Thank you for the quick response! I will read the other post. Thanks,
    Scott
    Ok Scott, sounds good.
    Oct 2011
    Oakdale, MN
    Yesterday it quit dispensing water and the light did not come on, when the getting water. I lifted the cover off but could not see anything. I then took off the 3 screws that hold the dispenser module, still nothing (I did find a broken piece off the actuator for my ice dispenser issue above)
    You may want to get a tech. to come out then, seems you have more than 1 problem.
  1. Replies: 16
    Last Post: November 28th, 2011, 09:51 PM
  2. FIXED: Makes ice but won't dispense
    By spotty8420 in forum Frigidaire/Electrolux
    Last Post: September 8th, 2011, 10:16 AM
  3. Replies: 3
    Last Post: March 15th, 2009, 11:49 PM
  4. Ice maker will not dispense ice
    By Kirby52894 in forum Whirlpool/Roper/Estate
    Last Post: January 19th, 2009, 06:48 PM
  5. ice maker makes an icicle in the front of maker
    By jamitc in forum Sears Kenmore
    Last Post: January 16th, 2006, 11:54 AM
Tags for this Thread
