Results 1 to 4 of 4
Thread: Maytag Performa Washer grinds when agitating only
    Oct 2011
    Asheville
    Default Maytag Performa Washer grinds when agitating only
    Model Number: pav3300aww
    Brand: Maytag
    My washer makes a grinding noise only when agitating, works fine otherwise. I can grab the agitator while it is in cycle and it stops spinning. Almost feels like the transmission is working and some plastic gears may be chewed up.. not sure how old this machine is, sn# 12432731ys. Any advice? Thanks, Mike
    Ok, you'll want to remove the agitator to see if the bottom base is stripped on the transmission shaft.
    Take off the fabric dispenser#9 and remove the screw#4 here:
    Then pull the agitator top#1 and agitator base#14 up from the transmission shaft.
    Here's the agitator base for your model:
    Manufacturer part number 21001530 is RepairClinic item number 436856
    21001530
    Oct 2011
    Asheville
    Not the agitator - I grabbed ahold of the transmission shaft top with my pliers, turned it and can feel the grinding noise...must need a transmission. I haven't looked under the cabinet but I assume the shaft coming up through the machine is the transmission and it is a one piece unit... probably not worth the investment, not sure how old the machine is, it was here when I moved in. Thanks
    Ok, then yes its the transmission thats bad. This washer is a 2000 model, so yes I'd save the repair money for a new washer.
    Here's the transmission for your model:
    Manufacturer part number 35-6615 is RepairClinic item number 1472816
    35-6615
  1. Maytag Performa Washer will not spin
    By jskaldorf in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 18th, 2011, 01:55 PM
  2. Maytag washer-not agitating
    By OMS in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 24th, 2009, 03:48 PM
  3. Maytag Performa washer wiring help
    By applyguy131 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 1st, 2007, 01:27 AM
  4. Maytag Performa washer
    By fd720 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 8th, 2007, 04:41 PM
  5. Performa: trouble agitating
    By Nathan Eddy in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 12th, 2006, 03:02 PM
