Results 1 to 10 of 17
Thread: Kenmore 70 series stops running after about 5-10 minutes
    Jun 2009
    crowley, tx
    Default Kenmore 70 series stops running after about 5-10 minutes
    Model Number: 110.66712694
    Ok, I'm not a mechanically inclined woman but this site helped me before fix my dryer and I'm hoping you can do it again! Here's the problem. After I start the dryer, it will run for about 5-10 minutes and then quit. After it sits for a bit, I can restart it but again after a few minutes, it quits. So, where do I begin?
    P.S. Small words and pictures work best
    Jul 2006
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jun 2009
    crowley, tx
    Thank you! I'll give it a try!
    Jul 2006
    Should you run into a problem, post it, and I'll walk you through it.
    Jun 2009
    crowley, tx
    HELP!! OK, did everything I thought correctly but when I tested it, it was really loud and something started to smell like it was burning?? What did i do wrong?!?!
    Jul 2006
    Check your wiring. Sounds like the motor is trying to run on 220 vac.
    Jun 2009
    crowley, tx
    How do i check it?
    Jul 2006
    Did the wires go on the motor individualy or is there a plastic connector with all the wires on it that connects to the motor?
    Jun 2009
    crowley, tx
    There's a plastic connector.
    Jul 2006
    On some of those connectors it's easy to be off by one terminal. Check that first. If it apears the wire connector is in the right spot, short the two door switch wires together and with the drum still out of the cabinet start the dryer on several cycles and see if the noise is still there. Turn the heat off so it's on air fluff. When you were replacing the motor did you run into any problems?
  1. Replies: 10
    Last Post: April 22nd, 2009, 12:29 AM
  2. Kenmore Series 90 model 110.76932691 stops running
    By RickTo in forum Sears Kenmore
    Last Post: February 11th, 2009, 11:33 AM
  3. 90 Series Washer - Smells hot and stops running
    By churn in forum Sears Kenmore
    Last Post: April 6th, 2008, 11:16 AM
  4. Kenmore 70 series stops after 10 minutes
    By Cubby007 in forum Sears Kenmore
    Last Post: October 28th, 2006, 10:36 PM
  5. Kenmore 70 Series (stops after a few minutes)
    By bsizemore in forum Sears Kenmore
    Last Post: May 13th, 2006, 06:39 PM
