Results 1 to 6 of 6
Thread: Kenmore dryer starts, runs for a few minutes, then stops
    Oct 2011
    PA
    Default Kenmore dryer starts, runs for a few minutes, then stops
    Model Number: 110.64082201
    I have read every post on this forum, and this seems to be a fairly common issue. Reading this post:
    http://www.applianceblog.com/mainfor...enting-ok.html
    I did the same thing, the tip off the thermistor was broken, so I replaced it, reset the circuit breaker, and the dryer will start, run for about 2 or 3 minutes, then just shut off, leaving the lights on. There is no error code on the panel, just shows the time left. The vents and lint covers have been cleaned.
    The heating element does start up and is nice and hot. When the dryer shuts off, the heating element goes out, and I can press the start button again, sometimes it will start up again, sometimes it wont. If it does, it only runs for a few more minutes, then shuts off again.
    Also, when it does run, from the back of the dryer, it smells a little like something is burning. Not sure if that's the motor burning out, or some lint that is burning, but it may be the motor?
    Anything else I can do? Is there a way to test the motor? At 8 years old, I do not want to replace the motor, but the $20 thermistor seemed like a nice try. Any other advice is greatly appreciated.
    Sounds like your motor is bad. A test to see if motor is any good, hook up a test cord to terminals 4 & 5
    on the motor, plug into a 120 volt outlet to see if the motor will stay running.
    Here's the motor for your model you can order here:
    Manufacturer part number 279787 is RepairClinic item number 158
    This video shows you how to get to the motor and replace it:
    Oct 2011
    PA
    Thanks Jake for the reply. Quick update since my last post: I let a full cycle run with no clothes in the dryer yesterday, and it ran all the way through. Then I threw in some wet clothes (shorts & t-shirts) and it dried it completely. Then another small load of shorts, underwear, and socks, and again it dried it completely. So I thought the dryer was back to normal.
    Then today I came home and threw in a load of 5 towels, and it went back to the same thing: running for 5 minutes, then shutting off. Not sure what that would indicate? The motor ran fine yesterday on the small items, but on the big heavy items of wet towels, it wasn't up to the task.
    Is that still indicating a motor problem? Thanks again for any assistance!!
    Yup, that indicates a bad motor.
    Oct 2011
    PA
    Thanks so much for the reply, I ended up getting a new dryer.
    Ok, thats fine.
  1. Dryer starts runs normally then stops cant be started
    By Toadman in forum Sears Kenmore
    Last Post: July 14th, 2012, 09:40 PM
  2. Admiral electric dryer runs for 5 minutes then shuts off - starts again after 5 minutes.
    By kettenhund75 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 17th, 2011, 12:10 AM
  3. Dryer starts, runs, then stops
    By Magic8Ball in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 28th, 2010, 08:48 PM
  4. Dryer Runs, Stops and Starts Again
    By fmwaz in forum Sears Kenmore
    Last Post: March 19th, 2006, 12:45 PM
  5. Replies: 3
    Last Post: December 10th, 2005, 05:07 PM
