Results 1 to 7 of 7
Thread: Kenmore Series 80 Gas Dryer - no heat
    Oct 2011
    California
    Default Kenmore Series 80 Gas Dryer - no heat
    Model Number: 110.76822690
    Age: More than 10 years
    Hi. Thought I could rely upon other threads...until I read more. So here's my specifics:
    Everything appears to run correctly, just no heat. I don't hear it firing up after a moment of spinning. Last use...someone put it on the highest heat setting (which we never do). Not sure how old this unit is.
    Model: 110.76822690
    Serial# MF4005511
    If I'm guessing correctly, I should check for continuity on the Thermal cut-off fuse, and High Limit thermostat. If that doesn't solve the problem...???
    Yes, its possibly the thermal fuse thats bad, on gas dyers a bad thermal fuse will make the dryer run but not heat.
    Here's the thermal fuse for your model you can order here:
    Thermal Fuse 3392519 Order now for same day shipping. 365 day return policy. RepairClinic.com
    This video shows how to access your thermal fuse:
    This video shows how to test it:
    The main reason the thermal fuse blows is air flow restrictions in your exhaust hose that goes to the outside of your home, lint build-up over the years effects the air flow, also go outside and check your dryer vent, that can clog up too.
    Now if the thermal fuse tests fine, you have one more to ohm for continuity, its your high-limit thermostat:
    High Limit Thermostat W10423382 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Oct 2011
    California
    OK...fuses passed continuity test. On to figure out how this thing lights up? Or should I be checking for something else?
    Ok, now ohm the igniter glow bar for continuity.
    Here's the igniter glow bar for your model:
    Igniter 279311 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Here's the video to access/change it:
    Here's how to test it:
    Oct 2011
    California
    Got it - it passed the continuity test. What's next?
    (BTW...awesome video & instruction...never would have made it this far without you!)
    Now check your motor heat switch, the motor heat switch contacts usually are 1 & 2 on the motor switch.
    Inglis-Whirlpool-Kenmore dryers, motor problems
    The #1 & #2 contacts on that black switch where the wires connect to.
    Use your multimeter on the ohms setting to check continuity between the #1 & #2 contacts. Take the wires off the contacts first, and make sure your dryer is unplugged.
    It should be open, not closed. Closed would show continuity, which is 0 ohms.
    Here's the motor for your model you can order here if your motor heat switch is bad:
    Drive Motor 279827 Order now for same day shipping. 365 day return policy. RepairClinic.com
  1. FIXED: Kenmore 70 series gas dryer won't heat at all now.
    By menzsa5 in forum Sears Kenmore
    Last Post: October 20th, 2011, 12:10 PM
  2. Kenmore series 80 dryer with no heat
    By acre1291 in forum Sears Kenmore
    Last Post: July 22nd, 2007, 12:51 PM
  3. Kenmore dryer 90 series - No Heat
    By Ray Fierro in forum Sears Kenmore
    Last Post: June 5th, 2006, 06:58 PM
  4. Kenmore Series 80 Gas Dryer/no heat
    By moboater in forum Sears Kenmore
    Last Post: October 1st, 2005, 01:13 AM
  5. Kenmore 80 series dryer, gas, no heat
    By heffemontana in forum Sears Kenmore
    Last Post: May 1st, 2005, 09:16 PM
Tags for this Thread
