Results 1 to 5 of 5
Thread: Amana ALE643RBW Dryer Will not dry clothes
    Aug 2011
    U.S.A.
    Default Amana ALE643RBW Dryer Will not dry clothes
    Model Number: ALE643RBW
    Brand: Amana
    The heating element comes on for about 30 seconds then goes off ,after about a minute and a half it comes back on for about 3 seconds and goes off. After that it stays off for a long time then comes on for a second or two and goes off.
    Any ideas? Thanks Dale
    Hi Dale,
    We need the complete model# of your dryer.
    Click here to locate it.
    Nevermind, I see it now.
    Pull the dryer out from the wall and take the vent hose off then run it without clothes and see if the element cycles normal.
    Aug 2011
    U.S.A.
    I took the vent hose off the element came on for 30 seconds was off for a minute 45 seconds came on for 3 seconds
    was off for two minutes and a half on 3 seconds and off. The inside in slightly warm not hot,and it's been running 15 minutes. I checked the element reading of 10.0 High limit thermostat read 0.1 to 0.3 thermal fuse read 0.1 to 0.5
    Thanks Dale Ok I was checking things out and found a loose terminal on a wire from the element to the high limit
    thermostat, I put a new wire and terminals on and it works fine.
    Thank you for time Dale
    Excellent Dale, good job finding that loose wire terminal.
  1. Gas dryer - heats up - clothes wet
    By wetclothesnow in forum Sears Kenmore
    Last Post: June 26th, 2010, 02:08 PM
  2. Dryer does not heat up to dry clothes
    By pango in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 6th, 2007, 06:06 AM
  3. Dryer Stains Clothes
    By Mannfamily in forum Frigidaire/Electrolux
    Last Post: January 15th, 2007, 10:06 AM
  4. Dryer will not dry clothes
    By jhall in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: July 31st, 2006, 07:30 AM
  5. Amana Dryer Not Drying Clothes
    By FlexKavana in forum Amana
    Last Post: February 11th, 2006, 07:52 PM
