Results 1 to 4 of 4
Thread: Whirlpool Dryer (No Heat)
    May 2009
    Fremont
    Default Whirlpool Dryer (No Heat)
    Model Number: GEQ9800LG0
    I have a Whirlpool Electric Dryer that does not Heat up. Spins fine, but no heat. I thought for sure it would be the heating element, but the heating element is good. What other things should I be looking for that would not allow heat??
    Jul 2006
    First check the circuit breakers and make sure one didn't trip. Then check the power cord where it connects to the dryer and make sure one terminal hasn't burned off. If they check good, I'll help you troubleshoot it. Do you have a multi-meter that can read AC Volts and Ohms?
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    May 2009
    Fremont
    Circuit Breaker is fine, and and Terminal Block is good and not burned. I do have a Voltmeter and Ohm Meter and would appreciate the help...thanks a lot.
    Jul 2006
    First, confirm 220 VAC at the terminal block where the power cord connects. Then unplug the dryer and remove the lower front panel. Set your meter to read continuity. Always remove at least one wire from the part you're testing and check #47-#48- #59 and #42 for continuity. They should all read closed. Hopefully that's as far as we'll have to go. If I was to guess, I'd say #47 is the culprit.
    Attached Files Attached Files
  1. Whirlpool Dryer Won't Start; Heat OK
    By CRISVICK in forum Whirlpool/Roper/Estate
    Last Post: February 27th, 2011, 01:36 AM
  2. Whirlpool Gas Dryer LGR5848EQ3 no heat
    By mktmom46 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 14th, 2007, 02:00 AM
  3. Whirlpool Duet Dryer - No heat
    By jwpetree in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: February 18th, 2007, 12:26 PM
  4. whirlpool dryer no heat after 15 min
    By tlz316 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 15th, 2006, 11:37 PM
  5. my whirlpool dryer will heat up but not dry my clothes
    By angel2211998 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 17th, 2005, 09:28 PM
