Results 1 to 10 of 14
Thread: Kenmore micro hood stopped heating and is making a loud humming sound
    Nov 2010
    Ga.
    Default Kenmore micro hood stopped heating and is making a loud humming sound
    Model Number: 721.80419500
    My Kenmore OTR microwave start making a loud humming noise, and stopped heating. All else works fine (except for the lights underneath which stopped some months ago). The turntable, exaust fan, interior light, clock all work fine. I unplugged it for a while and plugged it back in and the humming starts(without trying to heat anything). Can anyone advise on these problems. I really don't want to replace it. I'd love to be able to fix it. Much thanks on any info.
    Jul 2006
    You're probably going to have to take the control panel off and see where the hum is comming from. Re-check your model number. Nothing comes up with that one.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2010
    Ga.
    oops! my bad. The mod # is 721.80419500. Sorry
    Jul 2006
    If it starts making the noise as soon as you plug it in, the control board must be the culprit. That's the only component that has power going to it to light the display. Unfortunatly, that part has been discontinued.
    PC Board 6871W1S128C Order now for same day shipping. 365 day return policy. RepairClinic.com
    Nov 2010
    Ga.
    Thanx Rick for the advise. I found the part, I was wondering if there were a how-to on getting at the old control board and installing the new one. Any info is much appreciated.
    Thanx a mil.
    Jul 2006
    There is a single screw on the top of the control panel but you might have to remove the top grill to access it.
    Nov 2010
    Ga.
    Got it. I can't thank you enough Rick. You da man!
    Nov 2010
    Ga.
    Got the new control board today, installed it, the lights underneath work now, as well as the fan, clock, but still no heat. Still makes a little humming, but only when trying to heat something. Any suggestions Mr. Rick? It's 5:50am here. I'll try and grab a lil shuteye and check back later. Thanks guys.
    Jul 2006
    UNPLUG THE MICROWAVE AND SHORT THE CAPACITOR TERMINALS BEFORE DOING ANY TESTS
    If it only makes the noise when heating or trying to heat it will be one of the high side components. It's common for a bad or shorted diode to cause this. It should read closed in one direction and open in the other. Check the capacitor terminals to the capacitor case for a short. Here is the diode:
    Diode 6021W3B001R Order now for same day shipping. 365 day return policy. RepairClinic.com
    Nov 2010
    Ga.
    I'm not sure how to perform these test. I don't see the capacitor case. Do I have to dismount the microwave and remove the cover? An internal diagram would be very helpful if possible. Thanx guy's.
  1. Freezer making loud humming sound
    By raf28arts in forum Frigidaire/Electrolux
    Last Post: May 3rd, 2011, 12:27 PM
  2. Replies: 1
    Last Post: April 17th, 2011, 07:40 PM
  3. Whirlpool Dishwasher Making Loud Humming Noise
    By hnovo4 in forum Whirlpool/Roper/Estate
    Last Post: February 11th, 2010, 12:22 PM
  4. Kenmore Micro/Hood Combination Light
    By rdphill in forum Sears Kenmore
    Last Post: August 20th, 2006, 10:10 PM
  5. Kenmore Micro/Hood combo problem
    By mcmgcm in forum Sears Kenmore
    Last Post: January 31st, 2006, 07:25 AM
