Results 1 to 8 of 8
Thread: GE Washer doesn't go into high speed spin.
    Nov 2011
    NY
    Default GE Washer doesn't go into high speed spin.
    Model Number: WKSE6280B2WW
    Brand: GE
    All features and cycles of the washer works, but doesn't kick into high speed spin. When it tries to go into high speed, it kicks back and tries again every few seconds making aloud noise and recoils back and forth.
    Oct 2004
    WKSE6280B2WW
    A top load.
    ?Recoils?
    Sound anything like this...
    http://www.applianceaid.com/genew3.html
    Appliance Repair Aid
    Nov 2011
    NY
    Thanks for the prompt response.
    No Jeff...doesn't sound like that. It runs fine in slow spin. When it tries to go into high speed spin it bucks back and forth when it tries to engage high speed ... like the brake goes on and off. Once in a while it does engage into high speed spin OK, but mostly not.
    I have a video...can I send it to you?
    Its better that you upload the video to youtube and post the link here.
    Nov 2011
    NY
    Jake:
    Here is the link to the video showing the problem when it does not shift into high speed spin ....... GE Washer Will Not Shift into High Speed Spin.3GP - YouTube
    Here is the kink to the video showing the correct upshift to high speed spin ...... GE Washer Correctly Shifting into High Speed Spin.3GP - YouTube
    Its likely the motor thats bad. Jeff do you agree?
    Here's the motor for your model you can order here:
    Manufacturer's Number: WH20X10019
    Oct 2004
    No pun intended....sounds like it
    Won't find me spending $200+ on a GE washer....JMO!!
    Nov 2011
    NY
    OK .... Thanks guys !!
  1. High speed agitate and spin only
    By gn92lt1 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 7th, 2011, 11:09 AM
  2. Everything works but high speed spin
    By Whimsical in forum Frigidaire/Electrolux
    Last Post: June 26th, 2011, 04:45 PM
  3. No high-speed spin on front-load GE washer.
    By kmoore1861 in forum GE/Hotpoint
    Last Post: July 14th, 2010, 12:02 PM
  4. GE wbvh5200j2 Washer won't spin at high speed
    By nospin in forum GE/Hotpoint
    Last Post: October 14th, 2008, 11:22 AM
  5. MAH3000AWW Won't High Speed Spin
    By CWBR in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 20th, 2006, 03:32 PM
