Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: electrolux error F10 code
    Nov 2011
    st. louis
    Default electrolux error F10 code
    Model Number: EW30EF65GS
    Brand: Electrolux
    My Electrolux wave touch range after using the oven starts to beep continuously and displays an error code F10. When I cut the power it will stop beeping and work fine, unless the oven is used again. What needs to be replaced?
    Jul 2006
    Check the oven sensor. This video shows you how:
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2011
    st. louis
    Where is the oven sensor located on my range?
    Jul 2006
    In the oven
    Nov 2011
    st. louis
    Found it, thanks. I will pull the range out tomorrow to check it.
    Jul 2006
    Sounds good. Keep us posted.
    Yes, do what Rick mentioned first.
    F10
    Runaway Temperature.
    1. (F10 only) Check RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
    Your missing a letter after the "s" at the end of your model#, as they list 2 different oven sensors. Please post the letter after the "s".
    Nov 2011
    st. louis
    Replaced the oven sensor and I'm still getting the F10 error. Where is the EOC that I need to replace? Can't find the model #, the number I posted I took from Electrolux's website. The sensor I purched is part#316490000 and it was an exact match.
    Jul 2006
    I need the last number in your model number. There are different control boards.
    HELP ME FIND MY MODEL NUMBER
    Nov 2011
    st. louis
    Ok, pulled the range out again, no model # any where. I even removed the back panel and there wasn't one. I did notice the wiring diagram in the pouch on the back panel. For the EOC it gives part #ES630, but when I search for it no results.
  1. Electrolux Error 04
    By mgrant in forum Frigidaire/Electrolux
    Last Post: November 6th, 2011, 06:13 PM
  2. Fault Code F2 Error Code E6
    By bsmith in forum Whirlpool/Roper
    Last Post: February 20th, 2011, 01:11 PM
  3. Replies: 3
    Last Post: November 1st, 2010, 12:25 AM
  4. FIXED: Electrolux error code 11
    By JJones in forum Frigidaire/Electrolux
    Last Post: August 1st, 2010, 09:24 PM
  5. FIXED: Frigidaire/Electrolux Error DR Will not start
    By scgt1 in forum Frigidaire/Electrolux
    Last Post: July 8th, 2010, 11:47 PM
