Results 1 to 7 of 7
Thread: GE Profile Top Loading Machine stopping in mid cycle
    Sep 2010
    Indiana
    Default GE Profile Top Loading Machine stopping in mid cycle
    Model Number: WPGT9350COWW
    Brand: GE
    I have a GE Profile top loading machine that was in the home when I purchased it a year and a half ago. This past week it began stopping and shutting off in mid cycle. It seems there is not consistency when it shuts off. There have been times where it has stopped before the rinse and spin cycle, thus leaving the tub full of clothes and water. The only way I have found to remedy this is to manually go to the spin cycle setting.
    I have also seen the screen go black and the machine stop working at other points in the cycle though. It doesn't seem to be a consistent spot.
    Any idea what would cause this, and how can I fix it?
    Thank you!
    I haven't worked on any of these GE Harmony models, but here's the repair manual for it that may help you out:
    www.applianceblog.com/manuals/31-9103_GEharmonyWasher.pdf
    You have 2 major boards, the display board and control board that are extremely costly.
    Display board(WH12X10246):
    Manufacturer's Number: WH12X10246
    Control board(WH12X10245):
    Manufacturer's Number: WH12X10245
    Sep 2010
    Indiana
    Thank you for the response. I suppose I should call a repairman. It doesn't list anything in the manual...
    Sep 2010
    Indiana
    I pushed 'back' and my cycles' while in the help menu and received the two following issues...
    1. the inverter pcb has a history of not running properly
    2. serial communication link between main pcb and inverter pcb is down
    does this mean anything? it then told me it needed to be serviced. i had to unplug the machine, waited a few minutes and then plugged it back in. it ran though a setup or testing buttons, sensors, water system, etc. and said the machine is ready for use.
    thoughts?
    Nope, sorry, don't know anything about these.
    Did you try to use it when it said ready to use?
    Sep 2010
    Indiana
    yes i did try it. it stopped mid way through the rinse cycle. I tried to restart the cycle by going through the program and selecting 'rinse and spin', and it shut off before the rinse even started.
    we haven't decided if we are going to call a repairman, or just start researching a new washer. any advice on a new washer?
    I always recommend Whirlpool, very reliable. Front-load or Top-load.
  1. Kitchenaid Stopping In Cycle / Odd Progress Lights
    By Buckeye95 in forum KitchenAid
    Last Post: April 6th, 2010, 11:06 AM
  2. Replies: 1
    Last Post: April 27th, 2007, 12:30 PM
  3. Stopping during cycle
    By schwartd in forum Frigidaire/Electrolux
    Last Post: March 6th, 2007, 11:45 AM
  4. Maytag Performa stopping in spin cycle....
    By jgb95 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 3rd, 2006, 01:21 AM
  5. Washer KEEPS Stopping mid-cycle???
    By Cjden in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 14th, 2005, 10:30 AM
