Results 1 to 6 of 6
Thread: magic chef w/uniburners, oven problem
    Nov 2011
    Ohio
    Default magic chef w/uniburners, oven problem
    Model Number: 31FA-7
    Brand: Magic Chef
    Age: More than 10 years
    When lighting the oven, the pilot is lit but the burner (the thing will alot of holes in it and the flame comes out of it) will only stay lit for a couple sec. then it will go
    off for a couple sec. then back on for a couple sec. and will do this for hours.
    Thanks for any help!
    Jul 2006
    Re-check your model number. Read it from the range. Nothing comes up with that number. Look where manifold for that burner is connected to the surface unit valve and you'll see an air adjustment. Close it a bit more but not all the way closed.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2011
    Ohio
    yes it is a magic chef with uniburners model number 31FA-7. I got that from under the lid of the range top. It is a gas model. Please explain a little more. I do not know nothing about ovens.I do not know what a survace unit valve is. Is the air adjustment a screw?? Thanks for helping. Sorry I do know understand. I am looking right at it so if you describe it I will understand better. Thanks
    Jul 2006
    OK it sounds like there is a problem with the oven safety valve. When you turn the oven on, the pilot light kicks on a secondary flame on the bulb of the gas safety valve thermocouple. Make sure it is doing this and the thermocouple is in the right place. If it is then you may have to replace the gas safety valve and pilot assembly:
    Gas Safety Valve Assembly 7501P061-60 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Nov 2011
    Ohio
    Yes the secondary pilot does come on. Ok guess I will decide to fix it or buy new. Thank you!
    Jul 2006
    You're welcome! Happy Holidays!
  1. Magic Chef model # 34MN-23CKX Gas Oven problem
    By chiligirl in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 12th, 2009, 12:40 AM
  2. Magic Chef CAV4000AWW Problem
    By MorePower7701 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 11th, 2009, 09:40 PM
  3. Magic Chef Oven Problem
    By amgaan in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 3rd, 2007, 01:27 AM
  4. magic chef water problem
    By larry harding in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 16th, 2007, 10:43 AM
  5. Magic Chef with Uniburners
    By cc#1263 in forum Ranges/Ovens
    Last Post: November 29th, 2006, 05:01 AM
