Results 1 to 6 of 6
Thread: Kitchenaid KEYE670BWH3 Makes Buzzing Noise, Smells Slightly Hot, But Won't Turn Drum.
    May 2009
    Amory, MS
    Default Kitchenaid KEYE670BWH3 Makes Buzzing Noise, Smells Slightly Hot, But Won't Turn Drum.
    Model Number: KEYE670BWH3
    Brand: KitchenAid
    Age: More than 10 years
    This morning when we attempted to start a load of clothes, our dryer made a buzzing noise but wouldn't start rotating the drum. We shut it off.
    I attempted to rotate the drum by hand. It would not rotate clockwise at all, but it would rotate counter-clockwise very slowly and with much force applied to it. Normally, if I recall correctly, it will rotate both ways with not too much effort required.
    I held the door switch and attempted a push start of the drum while my wife pressed the start button. It did start spinning, but it was fairly obvious that it was struggling and it kept making a clicking noise until if finally stopped again. There seemed to be a slight overheating smell as well.
    My first question is, obviously, what could be the source of this problem? Is this a motor issue, a drive belt issue, etc.?
    Secondly, how do I disassemble this model to check it out? I have repaired my washer before, but never the dryer. Just quickly looking at it (I had to get ready for work) I couldn't see an obvious way to open it up to check the belt or other driveline components.
    Thanks in advance for your help!
    Jul 2006
    Yes, it's a motor issue. You'll probably need to replace it. Here is the one for your machine:
    Drive Motor 279827 Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    May 2009
    Amory, MS
    Is there a diagram available somewhere that shows the best way to disassemble this unit?
    May 2009
    Amory, MS
    Oh wait, I overlooked the video...sorry.
    May 2009
    Amory, MS
    I know this is overdue but I just wanted to say thanks for the reply and assistance. I was astonished at how easy this repair was. Thanks to the video, I was able to disassemble the dryer, completely clean the interior cabinet and components, replace the motor and re-assemble it in less than 30 minutes. Very, very quick and easy!
    Jul 2006
    Cool! Good job!
  1. Replies: 18
    Last Post: January 29th, 2016, 04:18 AM
  2. FIXED: Cabrio washer makes a grinding, buzzing noise when draining sounds like a stripped pump motor
    By JHUTCHINS in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 23rd, 2012, 03:05 PM
  3. Dryer Won't Turn; Makes Buzzing Sound & Smells Slightly Overheated
    By mlochala in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 28th, 2011, 06:19 PM
  4. Maytag MZD2768GE Water button makes buzzing noise
    By kellerh in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 6th, 2010, 03:34 PM
  5. Dryer makes buzzing noise when running.
    By miss_angel511 in forum Sears Kenmore
    Last Post: March 6th, 2006, 05:24 PM
