Results 1 to 10 of 12
Thread: Maytag MDB5601AWQ - drain motor hums but will not drain
    Nov 2011
    Iowa
    Default Maytag MDB5601AWQ - drain motor hums but will not drain
    Model Number: MDB5601AWQ
    Brand: Maytag
    My Maytag diswasher works fine except it will not drain at the end of the wash cycle. I tried the "rinse only" test and I can hear the drain motor hum but nothing happens. I tried the maual test and again the motor hums but doesn't drain. I ran the field test and the blinking lights indicate there is a Turbidity Sensor error. Are these two things related? What should I do?
    Oct 2004
    Check the drain pump, either jammed or bad...
ID:	3160 Pump assembly
    http://www.applianceaid.com/
    Appliance Repair Aid
    Nov 2011
    Iowa
    Default Thanks for the quick response
    How do I get to the drain pump? Do I have to pull the dishwassher out?
    Oct 2004
    Most times we don't have to pull out the unit, odd time we would have to. Remove power, remove lower access panals and the pump is normally on the back right.
    how to remove the access panals on a dishwasher for service Maytag Frigidaire GE Kenmore Whirlpool Inglis D&M
    #14 is the drain pump....
    Nov 2011
    Iowa
    I did remove the two panels underneath the door so I can see all the parts but since they are under the unit I'm not sure how I get to any of them. Is there a manual that gives me step by step instructions for cleaning and/or removing this pump? Sorry for being a bit challenged in this area. Can't afford a repairman right now.
    Oct 2004
    Not that I am aware of, a copy....
    1. Disconnect power to the machine.
    2. Remove Support and Toe Panel. (See paragraph FrontSupport and Toe Panel removal).3. Disconnect lead wire from Pump Assembly.4. Disconnect drain hose from Pump Assembly.5. Remove Torx™ screw through bushing in PumpMounting Plate.
    6. Rotate Pump Assembly to unlock from Tub.
    Drain Pump
    The Drain Pump will drain water from the Dishwasher invarious cycles. If a failure is suspected, the entire Pump
    Assembly needs to be replaced.
    Here's the repair manual for your model that will show you how on section 5-34:
    www.applianceblog.com/manuals/16021814.pdf
    Oct 2004
    A little bit older models on the manual but very similier
    Same blurb I copied
    Nov 2011
    Iowa
    Default Thanks - Jeff and Jake. I'll give it a try!
    Sounds good, keep us posted.
  1. Replies: 9
    Last Post: May 18th, 2012, 09:12 AM
  2. Maytag D/W: - drain after wash issue but cancel/drain works fine after....
    By disan2011 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 11th, 2011, 11:04 AM
  3. washer need drain motor
    By delroy in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 8th, 2011, 12:27 PM
  4. Drain motor
    By lan330 in forum Sears Kenmore
    Last Post: September 12th, 2010, 09:05 PM
  5. Kenmore 70 series hums, wont spin or drain or agitate
    By arnierobert in forum Sears Kenmore
    Last Post: November 22nd, 2005, 03:13 PM
