Results 1 to 4 of 4
Thread: Kenmore Ultra Wash Not Draining
    Dec 2011
    West Virginia
    Default Kenmore Ultra Wash Not Draining
    Model Number: 665.17012401
    My dishwasher is probably about 5 years old. About a week ago, it started making a grinding noise when the drain cycle would started, but it eventually went away so I chaulked it up as fixed. Now the dishwasher won't drain at all. If you run it, the dishwasher will shut off when the drain cycle should start leaving the tub full of water. If you hit the "Cancel/Drain" button, it makes a click sound like something is trying to engage then a light hum. I have taken the inside filter apart down to what I believe was the impeller looking for a clog and didn't see anything. I have disconnected the hose that connects to the house drain and it's not clogged at that point. Have I checked everywhere a clog is possible? Does it sound like the drain pump is bad?
    Oct 2004
    If the drain pump is not jammed up with something then the drain pump is likely bad.
ID:	3174 Drain pump assembly Manufacturer part number 661658
    Drain pump will just twist to come off...power off first!
    http://www.applianceaid.com/
    Appliance Repair Aid
    Dec 2011
    West Virginia
    Is the only way to tell if the drain pump is jammed up with something by pulling the machine and disconnecting the drain pump as the RepairClinic video for replacing the drain pump shows?
    Oct 2004
    Visually is the only way to tell.
  1. Kenmore Ultra Wash 3 not cycling or draining
    By newhallsr in forum Sears Kenmore
    Last Post: January 15th, 2011, 09:04 PM
  2. Kenmore Ultra Wash 665 Fills but no wash or drain
    By hornist in forum Sears Kenmore
    Last Post: May 16th, 2010, 03:59 PM
  3. Frigidaire Ultra Quiet 1....Water not draining after wash??
    By jmedero in forum Frigidaire/Electrolux
    Last Post: October 24th, 2007, 01:13 AM
  4. Replies: 5
    Last Post: June 4th, 2006, 11:54 PM
  5. Kenmore Ultra Wash - not draining
    By DaveT in forum Sears Kenmore
    Last Post: September 24th, 2005, 06:32 AM
