Results 1 to 6 of 6
Thread: Kenmore Elite Oasis Electric Dryer - No Heat
    Dec 2011
    Jacksonville
    Default Kenmore Elite Oasis Electric Dryer - No Heat
    Model Number: 110.6703
    We have a Kenmore Elite Oasis Dryer, 110.6703, that will run the cycle with no heat. Could this be the thermostat? I'm not really that great at repairing things, but with money tight and it being the holiday's I need to give this a go, so any help would be greatly appreciated. Thanks
    Jul 2006
    You can check the element, thermostats and thermal fuse for continuity but you'll need a meter that can read Ohms and volts, both AC and DC. The thermostats and thermal cut off will be located on the blower housing and element housing.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Rick is correct,
    Also Have you verified with a volt meter you have 220-240 volts? I've seen many times when 1 side of the dual breaker has tripped or a bad breaker would just cause dryers to run on 120 volts that the motor needs but not 220-240 volts to make it heat.
    220-240 volt 3 prong power plug test for a dryer
    220-240 volt 4 prong power plug test for a dryer
    The Kenmore Oasis is identical to the Whirlpool Cabrio.
    Here is the Cabrio dryer repair manual that may help too:
    www.applianceblog.com/manuals/Cabrio_Dryer.pdf
    Dec 2011
    CT
    Is the answer to this thread the same for model#110.87562602? Sears/Kenmore dryer not heating?
    Jul 2006
    Actually, you have a Whirlpool Duet dryer. Some tests are the same. Check the element and thermal fuse and thermostats for continuity.
    Yes, Rick is correct for your model too.
    If the fuse/breakers are fine, Its likely going to be either the heater itself or the thermal cut-off thats mounted on the side of the heater housing.
    Check those for continuity with your ohm meter with the wires removed from those 2 first, make sure you unplug your dryer first.
    You would need to take off the lower front access panel under your door, then take off the duct assembly#45, by removing the two #28 screws, and you may also have a screw at the very bottom of the duct assembly with a bracket attached to it, remove that one also.
    Here's the thermal cut-off#47 for your model you can order:
    Manufacturer part#279973 is RepairClinic item#897710
    279973
    Watch this video, the same applies to testing your thermal cut-off, Unplug or turn the breaker off to the dryer before opening the dryer up and ohm testing:
  1. FIXED: Kenmore Oasis Elite no heat?
    By rh455 in forum Sears Kenmore
    Last Post: July 16th, 2014, 10:44 AM
  2. Kenmore Elite Oasis- propane- no heat
    By Badburn in forum Sears Kenmore
    Last Post: July 8th, 2011, 03:25 PM
  3. [FIXED] Kenmore Elite Oasis - No heat
    By defoe91 in forum Sears Kenmore
    Last Post: September 9th, 2010, 10:16 PM
  4. Kenmore Elite Oasis 110.6703 Electric Dryer - No Heat
    By soldenka in forum Sears Kenmore
    Last Post: October 17th, 2009, 01:40 PM
  5. Kenmore Elite electric dryer no heat...
    By route62 in forum Sears Kenmore
    Last Post: January 10th, 2006, 04:40 PM
