Results 1 to 8 of 8
Thread: He3 Elite Kenmore Washer excessive vibration and noise
    Dec 2011
    Savannah, GA
    Default He3 Elite Kenmore Washer excessive vibration and noise
    Model Number: 110.45872400
    *Model Number 110.45872400* My front loader washing machine shakes, hammers and vibrates to the extreme during the spin cycle. It also makes a small rubbing noise when in the wash cycle. The drum spins easily by hand with a slight rub point. This all started at once and sounded like it would self-destruct, so I shut it down immediately. Is this something that a homeowner can repair or is it left only for repair service? Any information....tips, techniques, etc. would be greatly appreciated.
    Aug 2005
    Milbank, South Dakota
    Your model number is missing three digits.
    Were can I find my model number?
    Possibly your shocks, rear drum bearing, or inner tub spider arm is broken.
    Take the front bottom panel off first and check the shocks for excessive play.
    Here's the shock absorber for your model:
    Manufacturer's Number: 8182703
    8182703
    You would need to order 4 if you plan on doing this yourself.
    Dec 2011
    Savannah, GA
    Thanks for the help and part identification. I plan to take a look at this and see if it's something I can handle on my own. I'll let you know how things go.
    Ok, if the four shocks are fine, then the problem is either your rear tub bearing or inner tub spider support arm or arms are broken, check your warranty for both, some have a 10 yr. warranty on the outer tub assembly and a lifetime warranty on the inner tub.
    Dec 2011
    Savannah, GA
    Just an update on my problem. The Sears tech finally showed after 2 weeks (1st week cancellation due to illness & India customer service automatically put me out an additional week). Upon arrival, he checked the drum for slop and immediately told me the bad news (rear bearing/shaft) to the tune of $1300. This machine was an '03 model and looked showroom perfect in and out. The tech told me there was a 5 year warranty. Two people in the household and no abuse to the unit. I was informed this is not an unusual problem inherent to all front loaders. Needless to say how disappointed I am. Of course they still charge the service call to deliver the bad news. The only consolation was a partial reimbursement pending a new purchase from Sears. When we bought it, we paid $900+ to only last this long. I've had enough of Sears & Kenmore products for the time being, so I made another choice of machines...Maytag. I feel it's a crap shoot either way if front loaders are of vulnerable design failure in this area. I only wish I could use a top loader, but cannot due to space limitations.
    Aug 2005
    Your old sears/kenmore was manufactured by Whirlpool, same as your new Maytag. So in the end you ended up giving your money to the same people anyway.
    The tech told you wrong, you have a 10 yr. warranty on the outer tub assembly which includes the bearing, and Lifetime Warranty on the inner tub which includes the shaft, here's your manual, read the warranty on the warranty page:
    http://www.managemylife.com/mmh/lis_...M/L0502228.pdf
  1. Kenmore Elite Off Balance - Horrible Vibration
    By zero in forum Sears Kenmore
    Last Post: December 15th, 2011, 01:23 AM
  2. Whirlpool LA5668XTW1 washer excessive vibration
    By gdaarob in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: February 20th, 2009, 11:43 AM
  3. Sears HE3T - really excessive vibration
    By wschutz in forum Sears Kenmore
    Last Post: March 11th, 2008, 10:20 AM
  4. Kenmore 417.99570100 Dry Noise/Vibration
    By diels in forum Sears Kenmore
    Last Post: July 29th, 2007, 01:06 PM
