Results 1 to 10 of 11
Thread: State Select Water Heater Reset Button Tripping
    Dec 2011
    Raleigh,NC
    Default State Select Water Heater Reset Button Tripping
    Model Number: ES650DORS
    Brand: other
    I have a hot water heater that we have to reset the red button every other day. I am thinking that it could be that the water temp is set too high. I adjusted the upper water temp control, but didn't do the bottom at first. The water heater went longer without needing to be reset, but then it tripped again. I now adjusted the bottom temp down to the same level as the upper temp control. Hopefully this will work, but if it does not, should I then replace both thermostats? The only other item that I read that could be causing this would be the elements themselves, which involves draining the unit. Just want to make sure that I am on the right track.
    Seen this many times, usually you just need to replace the upper thermostat assembly.
    Dec 2011
    Raleigh,NC
    Jake:
    I replaced the upper thermostat and it worked for about a week and is now tripping again. Should I replace both upper and lower to rule both of them out. I turned the water temp down to make sure I didn't have it set to high, but that didn't help. Thanks for your help.
    Dec 2011
    Raleigh,NC
    One more question. When resetting the upper thermostat, should I be turning off the switch on the electrical panel, then resetting and then turning the switch in the electrical panel back on. Or should all I have to do is hit the red reset button on the upper thermostat? Not sure if it would make a difference or not.
    Yes, then replace the lower thermostat as well.
    Its best to turn the breaker off first, then reset.
    Nov 2008
    Middle Island ,LI, NY
    The question is why is it tripping ? You might be wise to install a GFI circuit breaker
    Retired US Army Refrigeration Specialist
    Retired NYC Board of ED Refrigeration Teacher
    HVAC/R and Building Maintenance Instructor
    NATE Certified Proctor
    Dec 2011
    Raleigh,NC
    Jake/Icehouse:
    I replaced the lower thermostat, and still the upper thermostat (which I replaced to begin with) is still tripping. I have attached an image of both thermostats so that you can see how they are wired. This is frustrating because I am renting the house, and the owners live out of town and haven't been much help. When it first happened they told me that it would trip every once in awhile and to just reset it by turning the breaker off and then hitting the reset button and then turning the breaker back on. Originally, this would only last for a few days and then it would have to be reset again. Needless to say, something is not right. The only thing that I can think of is that the hot water heater is not wired correctly. When I replaced the thermostats, I rewired them exactly the way that I found them. Based on the pictures, do you think they are wired correctly? If so, do you think it is an electrical issue with the power to the hot water heater?
    Attachment 3847
    Dec 2011
    Raleigh,NC
    Forgot lower thermostat
Name:	Lower Thermostat.jpg
    Dec 2011
    Raleigh,NC
    Just in case the first picture did not go through of the upper thermostat.
Name:	Upper Thermostat.jpg
    Yes, the wiring looks fine, but those wires are awful thin wires, never seen that thin of wires used on water heaters. What gauge wire is it?
  1. Replies: 3
    Last Post: September 19th, 2011, 03:55 PM
  2. FIXED: Simmer select button pops the breaker
    By jewing in forum Sears Kenmore
    Last Post: July 25th, 2010, 10:40 AM
  3. AO Smith vs. State Select
    By jlpicardq in forum Water Heaters
    Last Post: May 15th, 2010, 02:52 PM
  4. State Select power vent issues
    By 67 GT rag in forum Water Heaters
    Last Post: May 14th, 2009, 04:15 PM
  5. Reset button recessed
    By spiderg8r in forum Garbage Disposals
    Last Post: September 18th, 2006, 06:49 PM
