Results 1 to 10 of 10
Thread: Whirlpool Gold GT4175SPB-2 wont turn on
    Jan 2012
    Fresno
    Default Whirlpool Gold GT4175SPB-2 wont turn on
    Model Number: GT4175SPB-2
    my unit was manuf in 2006 and has always worked fine. It now wont cook when you hit start. All functions seem to work fine except the turntable and actually heating. It will countdown like it is working, but is not heating. Keyboard allows all functions to be entered as normal. It makes an audible click when you push start and then 1 sec later another click that is less loud. The click sounds like it is coming from right behind the start button area at the lower right front of the unit. I have not taken anything apart as of yet. I have tried unplugging it to see it would re-set, but that did not help. Any ideas where to start?
    Oct 2004
    Jan 2012
    Fresno
    does a door switch explain the audible click? It seems to me that it is some kind of breaker or something that re-sets each time. If no further input from anyone then i will take it apart and start checking these tips, thx Jeff
    Oct 2004
    That is usually a relay on the PCBoard.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Jan 2012
    Fresno
    which leads you to believe what? Is it gonna need to be replaced if so or is it a fixable part without doing the complete board?
    Oct 2004
    So far doesn't sound like anything wrong with the board.....check the door and door switches!
    If you are concerned about the "click"...just sounds like a relay closing but nothing can happen cause the unit thinks the door is open.
    Jan 2012
    Fresno
    Turns out it was the bottom door switch. It was stuck. I removed it and whacked it and it came loose insdie and now works. Im gonna replace it tho in case there some little broken piece of solder or plastic in the case.
    Jeff, it is not like the switches you put the link for. It is a SUROX and has only two leads with a red button. Do you have those?
    Oct 2004
    The manufacturer has replaced part number 8183562 with this item, part number 4392027
    Those are the most updated version now, kit of two as well...
    Microwave door interlock switches, 2ea Manufacturer Number 4392027
    Jan 2012
    Fresno
    too many leads, mine only have two leads.
    Oct 2004
    Quote Originally Posted by MikeinFresno View Post
    You only use the 2 required for yours and leave the third blank.....some will use lower 2, outside 2 or all three depending on the model/style. Can't use a 2 wire switch to replace a 3 wire but can use a 3 wire to replace a 2 wire.
  1. Replies: 3
    Last Post: September 16th, 2011, 11:46 PM
  2. Whirlpool Gold wont make much ice
    By wascapsfan in forum Whirlpool/Roper/Estate
    Last Post: December 16th, 2010, 10:32 PM
  3. Replies: 5
    Last Post: November 20th, 2010, 03:04 AM
  4. Whirlpool Gold Dryer drum will not turn.
    By Gene3x in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 9th, 2008, 01:48 AM
  5. Whirlpool Gold Dryer wont stay on
    By hiddenknoll in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 15th, 2007, 06:23 PM
