Results 1 to 4 of 4
Thread: Amana Washer Stops Mid-Cycle
    Jan 2012
    Louisiana
    Default Amana Washer Stops Mid-Cycle
    Model Number: NAV5800-1088
    Brand: Amana
    My Amana NAV5800AWW washer was stopping mid-cycle (right about mid-way through the wash cycle). If I tried to restart it right away, it was dead, but after waiting a few minutes, it would restart, then cut off again after a few seconds. I figured it was a bad timer, so I bought a used one off of ebay and changed it. I ran the washer and it did exactly the same thing as with the original timer.
    I then thought the motor was overheating as it was fairly hot to the touch (the thing is, I’m not experienced with washer motors, so maybe what I thought was too hot was really normal). So I took the belt and pump off and ran the motor with no load on it. In that mode, when I turn it on spin, the motor runs for about 5-10 seconds, then cuts off, but then it will restart again by itself about 10 seconds later.
    Is this a case of a bad motor or a second bad timer something else?
    Oct 2004
    Certainly sounds like a motor overheating and shutting off on it's built in safety/thermal switch.
    Make sure everything moves freely and the belt is intact.
Size:  3.7 KB Drive motor assembly with pulley, 2 speed Manufacturer Number 27001215
    http://www.applianceaid.com/
    Appliance Repair Aid
    Jan 2012
    Louisiana
    Jeff,
    Thanks for the quick reply. Are there any tests I can run to be 100% sure it's the motor before I spend $189 for the part?
    Oct 2004
    Make sure nothing is locking/seizing up.
    Run until it quits...power to the motor and no go is new motor time.
  1. FIXED: Washer stops mid cycle
    By laggs in forum GE/Hotpoint
    Last Post: October 31st, 2011, 04:35 PM
  2. [FIXED] Washer Stops Mid Cycle
    By bucket415 in forum GE/Hotpoint
    Last Post: February 12th, 2011, 12:37 PM
  3. Washer stops mid-cycle
    By brianm4 in forum Sears Kenmore
    Last Post: September 14th, 2010, 08:56 PM
  4. Washer Stops Mid-Agitation Cycle
    By gregwils in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 20th, 2010, 04:23 PM
  5. Maytag Washer stops in Mid cycle
    By jgray in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 27th, 2006, 02:23 PM
