Results 1 to 5 of 5
Thread: Dishwasher wont stop running
    Jan 2012
    Fraser, MI
    Default Dishwasher wont stop running
    Model Number: SHU5312UC
    Brand: Bosch
    Age: More than 10 years
    Just replaced the water Inlet valve a couple days ago. Everything appeared fine. Now I am experiencing continuous running of the dishwasher. When it gets to the end the display says CL but it is still running. Now when i restart it the display shows 2H. I did test using Scrub and Economy button. It showed 21 the first time. Both light started blinking. The . second time I ran the test it showed O. When this originally was noticed and when the dishwasjer was started it showed 36 and counted down to 1. When I opened it and restarted it it went back to 13 and conted down to 1 except this time it went to CL but would not stop. This is where I am at now. Any suggestions??
    Oct 2004
    SHU5312UC
    You are missing a couple of digits.
    This only started after your repair? If yes, check the float behind the fill valve....if there is water in the base or if the float got knocked it may think the d/w is in a flood mode and will power on th drain pump all of the time as soon as you turn the d/w on.
    CL is suppose to be clean, that should be normal.
    Check your repair/fill valve/fittings/float first.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Jan 2012
    Fraser, MI
    Default Dishwasher won't stop running.
    shu5312uc/u12
    Jan 2012
    Fraser, MI
    How do I access the valve and valve switch?
    Oct 2004
    Quote Originally Posted by lakesidepi View Post
    Pull d/w out, remove left side panal.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  1. Jenn-Air Dishwasher Wont Stop Running
    By MMC in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 2nd, 2011, 11:55 AM
  2. Dishwasher KUDK02CRBL0 Doesn't stop running.
    By 6ksqft in forum KitchenAid
    Last Post: March 5th, 2009, 11:50 AM
  3. Maytag Fridge WONT STOP RUNNING
    By sheepdog in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 22nd, 2007, 05:27 PM
  4. commercial dryer wont stop running
    By sugarnspice82805 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 30th, 2006, 08:27 PM
  5. KitchenAid Dryer wont stop running
    By arrow_choi in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 23rd, 2005, 01:18 AM
