Results 1 to 10 of 19
Thread: Dishwasher leaks at front door
    Jan 2006
    Default Dishwasher leaks at front door
    Maytag DWU7400ABX sometimes, not always leaks from the bottom of the front door. Ive read some other posts and checked the spray arm for cracks, and the rubber seal around the door seem OK [I removed it cleaned it and the surface it sits on the dishwasher front ]. The grommet & latch look ok. We use the dishwasher twice a week and I say every 5th wash, it starts to leak and we see a puddle of water and then its time to get the mop out. I don't understand why it does'nt leak for every wash ?
    Sounds like it could be that rubber grommet on the inside of the dispenser door latch. If you could remove the inner door liner you may see it leak.
    Here is a link that should help: ApplianceAid
    Jan 2006
    Why would it not leak for every wash ? Does water build up over several washs and then come out the bottom of the front door ?
    What part am I looking for ?
    model DWU7400ABX
    Aug 2005
    Milbank, South Dakota
    Quote Originally Posted by qprint
    Soap cup door latch and gasket kit. *Bad gasket is a common cause for a door leak
    Aug 2005
    #3 could be lose too..
    Jan 2006
    and number 3 is ?
    Aug 2005
    # 3 is the Reservoir Nut, sorry thought the diagram in the above post would be enough.
    Jan 2006
    cant see diagram
    Please send again
    Jan 2006
    I made my own rubber grommet for the inside of the dispenser door latch, until I bought the new one, and now that I bought it, I dont know what side of the grommet faces away from the door ?
    The sleeve side faces away from the door onto that latch piece.
  1. Dishwasher leaking water at bottom of front door
    By Lighthouse Wife in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 24th, 2012, 07:50 AM
  2. Replies: 3
    Last Post: July 15th, 2009, 11:30 AM
  3. Brand new Dishwasher leaks at door -- 665.1371/665.1381
    By Holmesmic in forum Sears Kenmore
    Last Post: October 14th, 2006, 02:02 AM
  4. Maytag Performa Dishwasher Door Leaks
    By DBoone in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 20th, 2006, 01:17 AM
  5. Dishwasher leaks(pours) from front door
    By Curt in forum Sears Kenmore
    Last Post: August 6th, 2006, 05:33 AM
