Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Maytag freezer leaking onto floor, ice on bottom
    Feb 2006
    CT
    Default Maytag freezer leaking onto floor, ice on bottom
    Model Number: MSD2456GEW
    Brand: Maytag
    I have a Maytag Plus side-by-side fridge/freezer. I have been finding a puddle of water on the freezer side with a thin layer of ice on the bottom of the freezer.
    I saw other threads with the same problem in other models with solutions about a clogged drain. I removed the bottom shelves on the freezer and fridge and could not find this "drain", which I assumed would look like a hole....Should I be looking somewhere else for the "drain"? I hope this is the same problem for me
    Feb 2006
    CT
    very sorry about the double post, i had a computer problem when i posted the first time and didn't see it in the forum
    Jan 2006
    Toronto, Canada
    Quote Originally Posted by agd2002
    You will have to remove the rear evaporator shroud. The drain system is accessed from the interior freezer compartment; you will see several Phillips screws holding the rear panel to the freezer rear wall. Remove the rear panel and clear the drain system by removing the ice build up and poor boiling water down the drain to melt and residual ice and to assist in removing any debris that may be blocked in the drain system. Once the drain is clear you will notice water flowing down the drain as you poor it in. Please keep in mind that the defrost drain pan located under your Refrigerator may overflow if there is an excess amount of water.
    If you can provide me with the Model number of your Refrigerator I can give you a more detailed explanation if necessary.>>
    I hope this information has been of assistance to you.>>
    Feb 2006
    CT
    thanks for the quick reply, i'll try it out tomorrow, and get back with what happens
    Jan 2006
    Toronto, Canada
    I have attached a .pdf file of your Freezer compartment. Item number 20 is the Evaporator shrowd I was refering to.
    Feb 2006
    CT
    We tried it all out and fixed the clog today; however, in our attempts we also put a hole in the tubing.....here's the story
    we removed the shroud from inside the freezer, and poured water/bleach down the drain...we also (unfortunately) stuck a skewer stick in to clear anything since we didn't have a wire cleaner....we didn't know that the drain plug didn't go straight to the pan, and the resistance we felt was a rubber 90-degree short tubing....so we put a hole in that (we found this out by opening the back panel and seeing the rubber tubing there
    we have the hole fixed w/ duct tape right now and it's all working well, but we would like to replace that rubber tubing, but we do no know what to call it
    i tried to do a search for parts/rubber tubes, but have not come up with anything so far
    thanks for all the help though, this was a great solution to our problem
    Feb 2006
    CT
    also, i used the appliance parts finder in jake's profile and another one in an ad on this site, but they both say they cannot find my model number
    sorry i missed a number on the model number it is MSD2456GEW however, the diagram was still helpful...sorry for messing this up
    ok, so i can find the fridge, and the diagram w/ the tube, but they don't label the tube and give it a name
    Feb 2006
    CT
    i found it on one site.....linked w/ the drain hose which i don't need
    i guess i'll see if i can find it at a parts store first unless you guys know what it is/where to find it
    thanks
    Feb 2006
    Lake Norman, NC
    Did you remove the back panel exposing the freezer coils? It's generally below them. And if you have that much, you may have more trouble than a clogged drain.
  1. FIXED: Maytag freezer has thin layer of ice on bottom and water on floor
    By Frederick in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 5th, 2016, 04:20 PM
  2. Replies: 3
    Last Post: July 29th, 2013, 01:15 PM
  3. Maytag freezer leaking onto floor, ice on bottom
    By cfsanchez in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 18th, 2013, 07:39 PM
  4. Maytag MBR2258XES1 leaking water on floor, ice on bottom of freezer
    By Bmv in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 1st, 2013, 11:55 AM
  5. Maytag freezer leaking onto floor, ice on bottom
    By dunzer in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 23rd, 2012, 03:58 PM
