Results 1 to 9 of 9
Thread: KitchenAid dishwasher has become progressively louder
    Feb 2012
    Sacramento, CA
    Default KitchenAid dishwasher has become progressively louder
    Model Number: KUDS01IJBS0
    Brand: KitchenAid
    My KitchenAid dishwasher has recently become progressively louder during the entire wash cycle however still washes the dishes. I think it may be the bearing in the motor and am thinking i should just replace the motor. Any thoughts?
    Jan 2012
    Nashville, Tn
    I suspect you are correct. You can buy just the motor, which is much less expensive, but a little more labor intensive, or replace the sump/motor assy. The water seal does fail and cause rust/corrosion on the motor shaft/bearing, hence, noise. If the machine is closer to 10yrs, make sure all the racks are in good shape, the tub gasket isn't torn, the control panel isn't falling apart before you spend any $$. 10 yrs is pretty old for these "new" appliances. jb
    Yes, I agree with JBall.
    You have two choices below to order, the motor just itself, or the sump/motor assembly which includes the motor already installed into the sump, as well as a new chopper blade screen assembly, check valve.
    Here's the motor for your model you can order here:
    Circulation Pump Motor W10239404 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Here's the video to access/replace it:
    Sump/motor assembly, with the motor/chopper screen/check valve already installed:
    Circulation Pump W10239405 Order now for same day shipping. 365 day return policy. RepairClinic.com
    W10239405
    Here's the video to replace it:
    Keep us posted.
    Feb 2012
    Sacramento, CA
    Thanks all. I am ordering the motor now.
    Ok, sounds good, keep us posted.
    Feb 2012
    Sacramento, CA
    Thanks all installed the new pump and other parts i ordered and the dishwasher runs great. Any ideas on how to eliminate the loud squeak when yuo open and close the door?
    Excellent, good job.
    Just spray silicone lubricant on the door springs.
    Jan 2012
    Nashville, Tn
    Or replace the door link kit. The original has friction slides and as the rope looses it's coating it becomes noisy. The new kit has two rollers and an improved design of the rope (link).
  1. Kitchenaid Dishwasher kuds01ijbt0
    By tjcdas in forum KitchenAid
    Last Post: April 28th, 2008, 01:03 AM
  2. KitchenAid dishwasher won't drain
    By jkir in forum KitchenAid
    Last Post: January 1st, 2007, 11:13 PM
  3. Kitchenaid Kudso2 Dishwasher
    By patti in forum KitchenAid
    Last Post: October 10th, 2006, 02:47 AM
  4. Laundry center dryer getting louder
    By robras in forum Sears Kenmore
    Last Post: May 23rd, 2006, 07:26 PM
  5. Kitchenaid Kuds25shwh1 Dishwasher
    By George2 in forum KitchenAid
    Last Post: July 9th, 2005, 02:09 PM
