Results 1 to 4 of 4
Thread: Burnt temperature sensor plug - what do you suggest?
    Feb 2012
    Texas
    Default Burnt temperature sensor plug - what do you suggest?
    Model Number: JKP15WW2WW
    Brand: GE
    Age: More than 10 years
    Thanks in advance, guys. My oven started kicking out F3 and then F2 codes, so I pulled the temp sensor to test it with my meter. The plug (male and female) have basically melted together... what next?
    1) Do I pull the oven and tie in a new female plug? (attaches to oven) And replace with a new temp sensor? If so, where can I get the female plug?
    2) Or should I cut the plug, solder in a new sensor? I'm cool with whatever you guys suggest.
    3) As the plug has melted, I don't want to solder the wrong wires together...Is there a "wrong way" to attach the temp sensor wirse? (+ and - side?)?
    4) Last question - my sensor is a #WB21X5301.... Will any oven temp sensor with this part number work? I'm seeing a huge range of prices for them ($25 listed for a Whirlpool/Kenmore Oven to $90 on the GE appliance part site).
    THANKS from TX!
    Oct 2004
    If the connection on the sensor or the wire harness is not
    applicable to your model, use two ceramic hi-temp wire nut connectors to splice the wires together. Strip insulation on each wire approximately 1/2" from the end.
    Nope.
    If just the connector, I'd bypass it with the ceramic marr nuts first....replace the sensor only if needed.
ID:	4080 Oven temp sensor WB21X5301
    http://www.applianceaid.com/
    Appliance Repair Aid
    Feb 2012
    Texas
    Hey Jeff, thanks man. Thanks for taking the time to respond.
    All great to know. My sensor tested as good -- so I'll go get a couple ceramic wire nuts and will give it a shot. Funny... I was hesitant about using the wire nuts as the rectangular opening is pretty small.
    This oven has given me trouble before. I replaced the ECU eight months ago to fix an F2 error. She's worked great since then.
    I'll report back. Have a good one.
    Oct 2004
    Please do let us know how the repair goes
  1. Replies: 7
    Last Post: July 1st, 2011, 10:24 PM
  2. Temperature Sensor Going bad
    By nysecretweapon in forum GE/Hotpoint
    Last Post: January 23rd, 2011, 04:58 PM
  3. How to tell if a temperature sensor working properly?
    By ronnyruiz in forum Frigidaire/Tappan/Electrolux
    Last Post: November 23rd, 2010, 05:13 PM
  4. how to replace an oven temperature sensor
    By natalieware in forum Sears Kenmore
    Last Post: June 25th, 2006, 11:21 PM
  5. Error code FE30 Replace oven temperature sensor
    By Joannie in forum Whirlpool/Roper
    Last Post: February 27th, 2006, 09:23 PM
