Results 1 to 5 of 5
Thread: Stacked GE washer/dryer lights Blinking doeent start at all.
    Aug 2010
    Camarillo, California, United States
    Default Stacked GE washer/dryer lights Blinking doeent start at all.
    Model Number: GTUP270EM0WW
    Brand: GE
    Hi all you guys helped me before.
    SO at work we have a Stacked GE washer/dryer. model: GTUP270EM0WW. The top dryer is working fine...the lower washer does nothing when you close the lid. no water coming out, nothing. Nothing in none of the stages.
    I inspected it, and looked inside and saw that out of the two wires that lead from the lid actuator to a magnetic device, one of them was cut off. It appeared that maybe the washer wash shaking so bad that it cut of the wire off. I went ahead and crimped them back together hoping that would solve the problem but it didn’t.
    Before and after that fix, the status lights were this:
    STATUS:
    ON-lite,
    WASH-blinking
    Rinse-OFF
    Spin-blinking
    Lid lock-off
    I reset the circuit breaker for the laundry room; check to see that water supply was on,I discounted the power supply then reconnected it after Two minutes and nothing. Same status lights were blinking.
    There was a point in my testing that I closed the lid a litter harder than regular and the lid was in locked mode. But the status lights were the same as mentioned. But nothing really happened. I try to replicate what I had just done but nothing happened.
    Any advice would be greatly appreciated
    JOSE
    Apr 2012
    NYC
    Jose: We have the same problem with the same machine. I put the two wires together with no result. What was the solution to your problem? Many thanks in advance.
    Aug 2010
    You might have already fix the problem but I solved the problem. Turns out that the blinking lights were setting off a code. in my case it was activating a "BAD lid SWITCH" after a fix. You have CLEAR THE ERROR CODES.So the machine could Reset. By rotating the washer knob to position 4 and press and hold the START/ PAUSE button. The indicator will flash during this process. Release the start/pause button after 3 seconds. Press and hold the start/pause button and fabric softer button while rotating the knob to position tn 6 to exit diagnostic.
    Dec 2012
    san diego
    i got the same problem by what do you mean postion 4?
    Aug 2010
    yea that 2nd link....I don't know what happened I looked at it again its super small. i had got that diagram from that site..which is the TECH Manuel. have u opened up the machine and see if the TECH Manuel is inside the machine somewhere...its usually behind the control panel...anyways
    position 4 is the position from 12 o clock.(on washer dial settings) going in clock wise-pattern...which would be MEDIUM(delicates)
    position 6 is Medium (permanent press)
    i will see if i have the original TECH Manuel at work. tomorrow.
  1. FIXED: 3 Lights Blinking - Random Start
    By sobeat in forum Whirlpool/Roper/Estate
    Last Post: September 4th, 2011, 04:53 PM
  2. Lights were blinking, now will not start
    By gbrunelli in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 8th, 2011, 12:18 PM
  3. [FIXED] blinking green lights wont start
    By codigoe in forum Sears Kenmore
    Last Post: March 26th, 2011, 06:50 PM
  4. Dishwasher won't start; simultaneous blinking lights
    By spaniard25 in forum GE/Hotpoint
    Last Post: November 26th, 2010, 02:39 PM
  5. KUDP02FR Won't Start - Blinking lights
    By threekranes in forum KitchenAid
    Last Post: September 24th, 2007, 10:56 AM
