Results 1 to 10 of 12
Thread: Whirlpool Microwave will not heat, everythings else works
    Feb 2012
    Brighton, MI
    Default Whirlpool Microwave will not heat, everythings else works
    Model Number: WMH1162XVS-2
    How do I determine what is preventing the Microwave from heating - magnatron, diode, heat sensors? What do I check first? How do you discharge the capacitor before working on it?
    Nothing appears burned inside (from a power surge or short). door switch relays appear to function properly.
    I do not want to start replacing parts like the magnatron ($141) if it could be a temperature sensor ($15).
    Thanks for any help,
    Brian
ID:	4227Click image for larger version.
ID:	4228Click image for larger version.
    Oct 2004
    LINK> Many GE OTR microwave models however have a defect in the microwave distribution system which causes the magnetron tube to overheat
    LINK> Microwave parts how to test capacitors, switches, magnetrons high voltage diodes
    Use a metal ( not the shiny chrome type ) screw driver with a insulated handle to short across ( touch both at the same time ) the terminals of the high voltage capacitor to discharge it. With the microwave unplugged.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Feb 2012
    Brighton, MI
    All the resistances seem to check out fine except for the blocking diode connected from the capacitor to the chassis. No resistance measurement at all either way. Could this be the only thing causing the microwave not to heat? Or is there something else that usually goes out before or after the diode?
    Resistance testing:
    Fuse
    Capacitor
    Diode
    Magnetron
    Brian
    Oct 2004
    Are you creating high voltage?
    Unless you have an really expensive meter you may not see a reading on the diode....the fact that it does not come up as shorted is the best news you have with ohm testing it.
    A bad diode normally causes a growling noise and no heating.
    A diode can damage the mag, a mag can damage the diode, we often change them out together now.
    Feb 2012
    Brighton, MI
    Jeff, thanks for your help. The microwave is working again.
    Brian
    Oct 2004
    What was the problem?
    Feb 2012
    Brighton, MI
    Magnetron
    Oct 2004
    Thankx for the update, that should help others
    Jun 2012
    Houston
    Hi I don't know anything at all about microwaves but mine isn't heating if it does it doesn't even get to lukewarm. Can anyone help?
    Oct 2004
    Make, model#, approx age?
    Where is my model#, I need a part, where should I look for my model number
    mine isn't heating
    Runs and sounds ok?
  1. Magic Chef Microwave, everything works but it does not heat
    By rte cat in forum Maytag/Jenn-Air/Magic Chef
    Last Post: August 17th, 2011, 08:24 AM
  2. Whirlpool MH6150XMS microwave will not heat
    By Carroncaron in forum Whirlpool/KitchenAid
    Last Post: April 30th, 2010, 03:57 PM
  3. No Heat - Whirlpool GH5176XP Microwave
    By alohatech in forum Whirlpool/KitchenAid
    Last Post: January 3rd, 2009, 05:56 PM
  4. Whirlpool wont tumble, but heat works
    By machiavelli1512 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 28th, 2007, 02:39 PM
  5. Whirlpool ThinTwin dryer - works on low heat but nothing else
    By rdecourtney in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 10th, 2007, 10:17 AM
