Results 1 to 7 of 7
Thread: Why my microwave is blowing internal fuse?
    Feb 2012
    Miami
    Default Why my microwave is blowing internal fuse?
    Model Number: MH2175XST-1
    Hi,my wirpool MH75XST-1 over the range microwave is blowing the internal 20 amp. fuse when i try to use the microwave function only.it doesn't blow this fuse using the fan,lights or display.Any ideas?
    Oct 2004
    When...exactly?
    Opening the door, closing the door, when you press start?
    Q - My microwave went dead when I opened the door ( same problem as closed the door ).
    A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
    Q - My microwave blows the fuse inside itself as soon as I push the start button.
    A - Usually a shorted high voltage capacitor...see components section.
    A copy and tip from Prashanth:
    Description of problem (Maytag CMV1100Q) :
    Microwave stopped working while cooking. Replaced a
    20AMP fuse.
    When the cook cycle starts, microwave makes a groaning noise and stops. It loses power since the fuse is blown.
    Solution: High-voltage capacitor shorted. Replaced it and microwave works fine.
    Its located behind the fan underneath the high-voltage transformer.
    Remove the vent fan hood
    Remove the display control panel by removing the screw
    Take pictures of all the connections behind the control panel.
    Unhook all connections
    Remove the connections to fan
    Remove the fan
    Remove the screws and connections for interlocking switches.
    Make sure the high voltage capacitor is discharged!
    Remove the high voltage capacitor and replace
    Retrace the steps and put everything back.
    Microwave works great now.
    http://www.applianceaid.com/
    Appliance Repair Aid
    Feb 2012
    Miami
    Quote Originally Posted by jeff1 View Post
    When...exactly?
    20AMP fuse.
    Remove the fan
    Sorry,is doing it when i press the start button and works for 3 seconds before blows the fuse.
    Oct 2004
    Often a shorted HVCapacitor like mentioned above...
    Ohm testing a cap...
    Testing a capacitor
    Feb 2012
    Miami
    Testing a capacitor
    Thanks Jeff, I tried out the capacitor and everything went well, but when I removed the capacitor I noticed the HV transformer was fried. There was obviously a short there. I’m not sure whether I should replace the transformer or more importantly figure out what caused the short leading to the transformer burning out.
    Here's an image for reference:
Name:	Kendale Lakes-Lindgren Acres-20120226-00014.jpg
    I’ve been checking the prices for the transformers and they’re very expensive. My wife mentioned that she was cooking on the stove and there was a good deal of vapor rising up towards the microwave. Do you think it’s possible that the condensation from the vapor could have caused the short in the microwave’s transformer.
    Oct 2004
    Possible yes.
    HVTransformers don't go often but when they do we often see them cooked up.
    A little
    No pic Transformer, h.v. Manufacturer Number 8206343
    Jan 2012
    Nashville, Tn
    High voltage arcs like crazy when the humidity rises, just listen to the power lines when it's foggy out. Most likely the transformer will fix it. but they are not cheap.
  1. Whirlpool microwave blowing fuse
    By phil25rs in forum Whirlpool/KitchenAid
    Last Post: December 31st, 2010, 07:38 PM
  2. thermal fuse keeps blowing
    By chanchamone in forum KitchenAid
    Last Post: July 9th, 2007, 10:55 AM
  3. FIXED: DW blows internal thermal fuse on regular basis.
    By larryr in forum KitchenAid
    Last Post: June 6th, 2007, 12:49 AM
  4. Kenmore Microwave Oven Fuse Keeps Blowing
    By Belligerent in forum Sears Kenmore
    Last Post: June 7th, 2005, 11:54 AM
  5. Kenmore Microwave Oven Fuse Keeps Blowing
    By Belligerent in forum Sears Kenmore Reviews
    Last Post: December 31st, 1969, 06:00 PM
