Results 1 to 7 of 7
Thread: GE Profile Spectra XL44 Gas Range - no gas flow to oven and broil burners
    Feb 2010
    Elgin, Il.
    Default GE Profile Spectra XL44 Gas Range - no gas flow to oven and broil burners
    Model Number: JGBP90MEB2BC
    Brand: GE
    The 4 stove top burners all work nornally. Both oven and broil ignitors are glowing. Checked 120 VAC at the control panel between N and Bake, and between N and Broil when set to a specific temp. I would like to know how to specifically troubleshoot the dual safety valve. Thanks!
    DJS
    Feb 2010
    Elgin, Il.
    Any wiring diagram of the dual safety valve? Hand drawn would be ok too. Thanks again!
    DJS
    No wiring diagrams on GE, they don't provide them online.
    Are both bake and broil igniters glowing orange when you start each?
    Feb 2010
    Elgin, Il.
    Hi Jake,
    Yes they are both glowing orange, and the bake ignitor was just changed out for a new one. I will get the amp reading from the bake ignitor and let you know. Thanks for checking on the diagrams. It has 4 wires connected to the dual safety valve. 2 on top and 2 on bottom. I think the 2 white wires connected together are common. The other one on the bottom comes from the bake ignitor. And the other top connection is a blue wire that goes back up to the control panel or the broil ignitor? I will also check the resistance of all the electrical terminals on the dual safety valve. Thanks!
    DJS
    Yes DJS, it definitely sounds like a bad safety valve since you already replaced the bake igniter glow bar.
    Here's the oven safety valve for your model you can order here:
    Manufacturer's Number: WB19K14
    Feb 2010
    Elgin, Il.
    Hi Jake,
    It's fixed! here's what I found during troubleshooting this issue. I checked the resistance on the oven safety valve to be 1.6 ohms on both sides. Then I checked the current to the valve while calling for bake and found 2.65 amps which is in the correct range. Still no gas flow to the oven when calling for bake or broil. Then I removed the incoming gas pipe to the oven safety valve to see if any gas was flowing and found none. So now I am looking and suspect a faulty regulator since the stove top burners were normal. As I am looking and feeling around the regulator I found a loose red tab behind it and noticed where it belonged. It fell off the regulator that holds the valve open to the oven safety valve. I was unable to put it on without taking out the regulator and then able to fit it on correctly. Not sure how if fell off, but that's all it was! Thanks for all your help!!!
    DJS
    Ok DJS good find, glad that was all it was.
  1. FIXED: GE Profile (Spectra?) XL44 Oven won't heat up
    By CPH in forum GE/Hotpoint
    Last Post: May 18th, 2016, 12:24 PM
  2. FIXED: No Spark or click on all burners - GE XL44 gas range
    By DJS in forum GE/Hotpoint
    Last Post: January 17th, 2012, 11:02 AM
  3. FIXED: GE Spectra XL44
    By Tills in forum GE/Hotpoint
    Last Post: September 23rd, 2011, 12:15 AM
  4. Replies: 2
    Last Post: February 22nd, 2011, 03:31 PM
  5. Replies: 3
    Last Post: February 19th, 2011, 11:09 AM
