Results 1 to 6 of 6
Thread: Frigidaire wont agitate or spin
    Mar 2012
    FL
    Default Frigidaire wont agitate or spin
    Model Number: GLTR1670AS0
    Brand: Frigidaire
    Hi.
    I recently moved and put my washer in my new home. The first load in it and it would not agitate. Doing some troubleshooting I figured the motor was bad. Replaced it and now still have the same issue. The washer won't agitate and will start to spin but stops. It makes a loud humming noise however nothing happens. Any ideas would be helpful.
    ***The machine is 7 yrs old.
    Jul 2006
    If your machine is less than a year old you should still be under warranty. Don't do any more repairs or you risk losing your warranty. Call frigidaire for a warranty repair.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Mar 2012
    FL
    I edited to reflect age of machine.
    Jul 2006
    Remove the six pin connector from the speed control board. Check between pins 5 and 6 in the harness for 120 VAC. No volts would indicate the timer or timer connection is faulty.
    Mar 2012
    FL
    Quote Originally Posted by rickgburton View Post
    Sorry for the late reply. There is a 8 pin, not 6. Im fairly dumb come to electric things like this, do I test with the machine on or off?
    Do you see a ten pin?
    Thats odd, never seen an 8 pin connector.
    Rick hasn't been here the last few days.
    But it definitely sounds like the motor control board is bad.
    Here is the motor control board for your model you can order:
    Manufacturer part number 134149220 is RepairClinic item number 1206430
    Spin control board assembly
    All parts come with a 365 day full refund, even if you installed them.
  1. wont agitate or spin
    By nofchowski in forum Sears Kenmore
    Last Post: August 8th, 2011, 05:06 PM
  2. Wont spin or agitate?
    By lint in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 27th, 2011, 10:04 AM
  3. GE Washer wont agitate or spin
    By Kamdyn in forum GE/Hotpoint
    Last Post: March 28th, 2011, 01:22 PM
  4. Replies: 4
    Last Post: July 8th, 2005, 07:20 PM
  5. Will fill, will drain, Wont agitate, wont spin.
    By IAMWOMANDAMMIT in forum Washers
    Last Post: February 18th, 2005, 05:08 PM
