Results 1 to 6 of 6
Thread: <GE Profile XL44 >Stove top burner poor/weak flame
    Mar 2012
    NYC
    Default <GE Profile XL44 >Stove top burner poor/weak flame
    Model Number: XL44
    Brand: GE
    Age: More than 10 years
    I am experience very poor flame on the 4 stove top burners. The flame contains some yellow and is weak. It requires a long time to boil or cook anything, since the gas usage has gone up.
    Other issues: 2/4 burners emit gas when lighted. Although I hear clicking when turning on the burner, all burners require a match.
    Should I fix it or replace it?
    Thanks.
    Oct 2004
    Model#?
    XL44 isn't it.
    http://www.applianceaid.com/model.html
    Occured at the same time, different times?
    [Should I fix it or replace it?
    Poor flames, taking too long to cook, ignition problem, some kind of gas emited problem....might be a good idea to look at some new ones.
    Appliance Repair Aid
    Mar 2012
    NYC
    Sorry for the vague information. Here are some additional information:
    GE XL44 Self-Cleaning Gas Range
    Model# JGBP35GEP4WG
    2 or 4 burners emit gas odor when used. There are soots at the bottom of burners.
    Below is a picture of the high out burner flame.
    If the gas range can not be fixed, do you have any recommendation for a basic gas range for my parents.
    Thank you.
    Oct 2004
    Frigidaire makes some decent gas ranges...
    Ranges & Stoves | Induction, Gas, Electric & Dual Fuel Ranges and Stoves | Frigidaire Appliances
    Flame looks like a pressure issue....regulator, stem valve, both.
    Mar 2012
    NYC
    Thanks Jeff for quick response.
    Do you have the part# and location for the regulator and stem value. Is it a DIY or should I hire a professional?
    Have a great weekend!
    Oct 2004
    Stem valves are under the knobs....high, low, lite. Regulator is where the main gas supply enters the range.
Size:  3.0 KB Burner control valve Manufacturer Number WB21K14
ID:	4390 Pressure regulator Manufacturer Number WB19K15
  1. GE XL44 gas stove
    By wrench1 in forum GE/Hotpoint
    Last Post: February 16th, 2012, 02:56 PM
  2. Frigidaire #FGFL67DCA burner has weak flame
    By PJMonty in forum Frigidaire/Tappan/Electrolux
    Last Post: July 28th, 2011, 02:01 AM
  3. Gas dryer w/poor flame
    By TarotDream in forum Sears Kenmore
    Last Post: February 13th, 2011, 02:19 AM
  4. Replies: 3
    Last Post: June 29th, 2007, 12:51 PM
  5. GE XL44 Left Front burner ignitor inoperable
    By Ian in forum GE/Hotpoint
    Last Post: October 10th, 2005, 10:54 PM
