Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Kitchenaid Dishwasher leaving particles in glasses on top rack
    Jul 2011
    Georgia
    Default Kitchenaid Dishwasher leaving particles in glasses on top rack
    Model Number: KUDP02CRBS2
    Brand: KitchenAid
    Hello everyone!
    Recently I have started to notice the glasses on the top rack of my dishwasher are not coming clean. They will come out with particles inside, outside, and at the bottom of the glasses.
    The bottom rack cleans perfectly fine.
    Any advice would be greatly appreciated...or a schematic so I can open up the catch or check the upper spray arm?
    I'm not sure exactly what I should do...
    First check your sump basin.
    Watch this video first:
    Keep us posted.
    Jul 2011
    Georgia
    Jake, great video...thank you very much
    I found so much glass and a ton of food...bleh that was nasty!!
    But now it is all clean...will be doing a wash tonight and will update you with results in the morning.
    Ok, sounds good.
    Mar 2012
    IL
    Default Same problem with our KitchenAid Diwasher
    Ok, sounds good.
    We having been fighting the same problem with our KA dishwasher - KUDP02CRWH0. We cleaned out our sump area, re-did the hoses, used dishwasher magic, changed out the soap. We still get grit in glasses on the top rack. The glasses are sparkling clean with grit. My husband is ready to throw it to the curb.
    The main things to check is your water level in the dishwasher should come up almost to the heating element, your water temp. coming in should be 120-140 degrees.
    Read this about the gritty stuff:
    http://www.applianceaid.com/images/gritty-substance.JPG
    Mar 2012
    IL
    Thanks for the tip. We do run the hot water before we start up the dishwasher. We will double check the water level.
    We never put the glasses over the tine. We have been using a gel detergent. Over 50% of the glasses in the last load had grit. Everything on the lower rack was fine.
    I will let you know what happens.
    Ok, yes let us know.
    Mar 2012
    IL
    So I opened the door of the DW after it filled. the water level was about a half inch below the heating element. Good or bad?
    Perfect.
  1. Top rack leaving debris and particles on dishes
    By Monica Maharaj in forum Frigidaire/Electrolux
    Last Post: May 1st, 2013, 02:28 AM
  2. Glasses on top rack do not get clean
    By kgingras in forum Frigidaire/Electrolux
    Last Post: December 22nd, 2010, 11:22 AM
  3. Replies: 1
    Last Post: May 29th, 2009, 09:11 AM
  4. Kenmore leaving particles...
    By spotted dogs in forum Sears Kenmore
    Last Post: October 13th, 2005, 12:14 AM
  5. Replies: 1
    Last Post: July 13th, 2005, 11:51 PM
