Results 1 to 8 of 8
Thread: Whirlpool GEW9250PW1 Dryer will not start
    Mar 2012
    Miami
    Default Whirlpool GEW9250PW1 Dryer will not start
    Model Number: GEW9250PW1
    I have a whirlpool Duet GEW9250PW1 dryer, the panel lights up but when every I press start (or any other button) it just makes a beep noise. I put the dryer in "test mode" and I get a 09 code. Can someone tell what the problem could be? Also just a side note, before this problem started to happen, when I opened the dryer door there was a little spark as if maybe a fuse was blown but I didn't pay much attention to it.
    Thank you in advance!
    Oct 2004
    Didn't find anything on an 09.
    See tech sheet attached.
    Attached Files Attached Files
    http://www.applianceaid.com/
    Appliance Repair Aid
    Mar 2012
    Miami
    I looked online and it said it could be an "overflow condition"....
    Mar 2012
    Miami
    How do I put the dryer on test mode? I Press the following control panel keypad sequence all within 5 seconds: More TimeLess TimeMore TimeLess Time.
    Oct 2004
    Quote Originally Posted by buwnkle View Post
    On a washer maybe.....wouldn't think so on a dryer.
    Oct 2004
    From the tech sheet I linked to above...
    Be sure the dryer is in standby mode(plugged in and all indicators off).
    2. Press the following button sequence:More Time ➔ Less Time ➔ More Time ➔ Less Time – all within 5 seconds. 3. All indicators on the console are illuminatedwith 88 showing in the Estimated TimeRemaining (two-digit) display, if this test
    mode has been entered successfully.
    Mar 2012
    Miami
    I do that but it just displays 09...
    Oct 2004
    See if any of the plastic buttons are broken....but if it won't enter a test mode the controls would be suspect
Size:  3.2 KB Dryer user interface Manufacturer Number 8558755
Size:  3.5 KB User interface, pewter Manufacturer Number 8558756
Size:  3.9 KB Electronic control assembly Manufacturer Number 8546219
    You may return any part or product for any reason within 365 days of placing your order.
  1. Whirlpool Duet GEW9250PW1 dryer with no power
    By robras in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 17th, 2012, 01:42 PM
  2. FIXED: Whirlpool GEW9250PW1 - control panel won't come on
    By sienask in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 17th, 2011, 09:08 AM
  3. Whirlpool Duet Dryer GEW9250PW1 is possessed
    By Dano9454 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 9th, 2009, 04:21 PM
  4. Whirlpool Dryer GEW9250PW1 will not turn on
    By billman1167 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 14th, 2008, 05:14 PM
  5. Whirlpool Duet GEW9250PW1 Dryer
    By rhona in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 28th, 2007, 09:57 PM
