Results 1 to 6 of 6
Thread: The washer makes loud screeching noise when spinning
    Mar 2012
    S. California
    Default The washer makes loud screeching noise when spinning
    Model Number: LSB6000PQ0
    I have a Whirlpool. Model number: LSB6000PQ0. Been having it for about 7 years. Last few days, it makes very loud screeching noise when spinning at started for about 20 seconds, then lower and gone. Next spin, the sound's back again.
    Its pump was broken two months ago and I got the part and fixed. It's been fine since. Not sure if it's relate.
    Lets start with the simplest part first, check the motor coupling to see if the rubber is worn down on it, this part is just like a belt on belt drive models.
    You can also take the pump off and run it in spin and see if the noise is gone or not as well.
    You will need to by-pass the lid switch when you do this.
    Read here:
    Bypass Direct drive washer lid switch from consol plug
    Here's the motor coupling for your model:
    Manufacturer part#285753A is RepairClinic item#1195967
    Here's the video:
    Mar 2012
    S. California
    Replaced the motor coupling, noise still there.
    Leave the water pump off the motor then put the washer in spin and see if the noise is still present, if not, order a new water pump.
    Here's the water pump for your model:
    Manufacturer part number 3363394 is RepairClinic item number 3296
    Here's a video on how to access it:
    Keep us posted.
    Sep 2013
    texas
    FYI, for anyone else suffering the same symptoms, my squealing problem was the water pump. A piece of small plastic made it in there and got lodged inside so this fixed my problem.
    Jake, thanks for the help!
    Quote Originally Posted by brandonros View Post
    Excellent, good job.
  1. FIXED: MODEL # LSQ9600LW1 - Machine not spinning; Makes loud buzzing noise
    By rmu96 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 25th, 2013, 07:50 PM
  2. Kenmore washer makes loud noise when it starts to spin
    By dug031643 in forum Sears Kenmore
    Last Post: December 5th, 2011, 10:25 PM
  3. Maytag dryer makes screeching noise
    By csand19 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 7th, 2011, 03:55 PM
  4. Loud Screeching Noise/Pulsator Coming Off
    By Ronaldo807 in forum GE/Hotpoint
    Last Post: April 4th, 2011, 08:55 AM
  5. GE washer makes Loud thumping noise
    By dadsway in forum GE/Hotpoint
    Last Post: January 28th, 2007, 08:55 AM
