Results 1 to 6 of 6
Thread: Maytag Gas Range Burners Sometimes Do Not Light
    Mar 2012
    Wisconsin
    Default Maytag Gas Range Burners Sometimes Do Not Light
    Model Number: CRG9700CAE
    Brand: Maytag
    Age: More than 10 years
    The two front burners on this unit will not light unless one of the rear burners is already lit. When we try to light one of the front burners we can hear the clicking from the spark ignitor module and smell gas, but they will not light. I have already replaced one of the sealed burners thinking it was the ignitor in the burner, but this did not help. I now think I need to replace the spark ignitor module. If this is correct, where is this located or what wires do I need to trace to find the location?
    Jul 2006
    First make sure you can see the spark at the burner assembly. Remove the burner assembly and where the igniter sparks you'll see some small climber holes. Use a wire brush and clean them.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Mar 2012
    Wisconsin
    Not sure I know what you mean climber holes, but did take out one of the front burners and used a wire brush around the igniter. Also, cleaned the igniter with emery paper. All the holes look to be wide open as I can see through them when I hold the burner up to a light. Did not do this to the other side since that is where I installed the new burner. When trying to light a burner, I can see sparks on the two rear burners but no sparks are visible on the two front burners.
    Jul 2006
    OK, No sparks on either front burner then you were on the right track and it's most likely the spark module. It's located behind the range near the gas valve.
    Spark Module 12001596 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Mar 2012
    Wisconsin
    Thanks for confirming that it is the module that is bad. I was unable to find this by the gas valve so I traced the orange wires that lead to the burners. These all go down the right side of the unit to the module which is located in a box attached to the right rail of the drawer under the oven.
    Jul 2006
    Cool, good information. Thanks, they keep moving them on me.
  1. Maytag Range Model PGR4405CDT burners AND oven won't light
    By brmommy in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 23rd, 2012, 03:49 PM
  2. Kenmore gas range - oven burners won't light
    By squirkie in forum Sears Kenmore
    Last Post: January 19th, 2012, 07:45 PM
  3. range burners wont light
    By donbrown01 in forum GE/Hotpoint
    Last Post: November 19th, 2011, 02:06 PM
  4. Right side range burners won't light
    By Fp1 in forum GE/Hotpoint
    Last Post: January 25th, 2011, 12:49 AM
  5. Simple Kenmore range: burners won't turn on, light does
    By thinkmassive in forum Sears Kenmore
    Last Post: August 3rd, 2007, 10:46 AM
