Results 1 to 10 of 12
Thread: Frigidaire Upright Freezer Not Cooling Properly.
    Mar 2012
    South Carolina
    Angry Frigidaire Upright Freezer Not Cooling Properly.
    Model Number: LFFU14F5HWH
    Brand: Frigidaire
    My frigidaire upright freezer model #LFFU14F5HWH is not cooling properly, a couple of days ago I noticed the high temp. alarm going off, and the bottom shelf and drawer were warmer than the rest, the bottom half food is mushy, and everything up top is frozen solid. I pulled the cover to the evaporator and had a thin layer of frost on the top left corner of the evaporator. I manually defrosted the coil, and removed the food from the bottom half to see if the temperature would pick up about 30 minutes ago and have not checked it as of yet was going to give an hour or so and see where it is at. Not sure if it is a defrost problem or cooling problem, air coming out of vent at top is really cold, and fan is running. Any suggestions on what else to check or possibly what the problem may be would be greatly appreciated.
    Jul 2006
    The evaporator coils should have a very thin layer of white frost on all the coils, top to bottom. If you have very little frost on the coils then you possibly have a sealed system issue. If the coils are completely packed with frost and ice you most likely have a defrost problem.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Mar 2012
    South Carolina
    After removing the food from bottom two shelves, and removing the coil, it has been running for about an hour, when I checked it just now the coils did have a thin layer of frost on all coils, originally the ice was thick on the first coil, it has yet to cool down enough for the alarm to go off, at last reading it was at 40 degrees F, but I had the door open for a while removing the coil cover. My manual says it should take up to 4 hrs. for the temp. to stabilize, I will let it run over night and see where we stand in the morning.
    Mar 2012
    South Carolina
ID:	4581 Here is a picture of the coils after about 2 hrs. since I manually defrosted them, I have since removed everything from the freezer, and am going to let it cool overnight and while I am at work tomorrow and see what it does. Note the thicker ice on the top left, is this normal? Is this indicative of a defrost problem? Could this have anything to do with the cooling issue? Any help would be appreciated.
    Jul 2006
    The evaporator cover must be on when running. Is the fan working?
    Mar 2012
    South Carolina
    Quote Originally Posted by rickgburton View Post
    Yes the fan is working, today after work it has cooled down to right around 20 degrees F without anything in it, the defroster appears to be working, there is some ice on coils today, but not what I would say is enough to cause a problem, still don't trust it enough to put anything back, will watch it for a couple of days to see what happens.
    Jul 2006
    20*F is not cold enough. After looking at the picture of the evaporator again, and that's about 2 hours of running time after you defrosted it, correct? I looks to me like there's a problem with the sealed system. The frost pattern on the coils should be a very thin coat of white frost on all the coils top to bottom. The thin copper capillary on the bottom left side is where the refrigerant enters the evaporator. It starts out thick and like snow and then gradually there is less and less and by the time it reaches the third pass there is no frost on the rest of the coils. It could be caused by a partial restriction in the cap tube or filter/drier. It could also be an inefficient compressor. Let's see if I can get a second opinion first.
    Yes I read this entire thread and I agree with Rick, sounds like a sealed system problem.
    Check your warranty, some models have up to a 5 yr. warranty on the sealed system/compressor.
    Mar 2012
    South Carolina
    Yes sir that last picture was taken after about two hours, with freezer half emptied, here is a picture today taken about 5 minutes ago, freezer has been completely empty for 24 hours now, and still not cool enough, I went ahead and shut it down until I can get someone to look at it.
    Yup, now it definitely looks like a sealed system/compressor issue.
    Let us know what the Frigidaire tech. says.
  1. Kenmore upright freezer stopped cooling
    By DrOpera in forum Sears Kenmore
    Last Post: January 6th, 2011, 10:58 PM
  2. Frigidaire upright freezer not cooling
    By jlm in forum Frigidaire/Electrolux
    Last Post: September 21st, 2007, 01:16 PM
  3. Frigidaire upright freezer
    By Whitey741 in forum Frigidaire/Electrolux
    Last Post: February 25th, 2007, 08:30 PM
  4. FFU17FC5CW5 upright freezer not cooling
    By lisaf in forum Frigidaire/Electrolux
    Last Post: January 10th, 2007, 02:55 PM
  5. Upright Freezer Trouble Cooling
    By BC... in forum Frigidaire/Electrolux
    Last Post: May 22nd, 2006, 06:24 AM
