Results 1 to 5 of 5
Thread: Ice cubes in bin melt and freeze together
    Mar 2012
    Tempe
    Default Ice cubes in bin melt and freeze together
    Model Number: MTF2176HRQ
    Brand: Maytag
    Unit stopped defrosting 2 weeks ago, I had the defrost timer and thermostat replaced. Now the unit cools great and makes lots of ice, but the cubes melt in the bin and freeze together. Is the defrost cycle too long? Is the defrost timer adjustable? Freezer temp is between 0 and +10 degrees.
    Jul 2006
    The defrost timer's defrost cycle is about 21 minutes and is non-adjustable. That shouldn't produce enough heat to melt the ice unless the freezer was completely empty. Even then it shouldn't but does sometimes. Is the door seal closing good?
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Mar 2012
    Tempe
    Thanks for the reply. The seal apears to be good, lots of food in the freezer. The cubes on top of the bin melt, the cubes at the bottom do not. Didn't have this problem before timer was replaced. I'm mostly worried about my frozen food getting freezer burn from thaw/freeze cycles
    Jul 2006
    Did you replace the timer with the correct part. The defrost timer is 10 hour timer
    Defrost Timer 68233-3 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Mar 2012
    Tempe
    I'm not sure, I had a local service company do the repair. I will have to investigate. Thanks
  1. Replies: 7
    Last Post: January 24th, 2012, 01:02 PM
  2. Replies: 5
    Last Post: January 1st, 2012, 08:10 PM
  3. Replies: 23
    Last Post: November 5th, 2011, 02:11 PM
  4. Jenn-Air ice cubes don't freeze solid - dump water in ice bucket
    By pfe999 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 25th, 2009, 08:13 PM
  5. Maytag ice dispenser melt down
    By Critter in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 12th, 2007, 12:48 AM
