Results 1 to 2 of 2
Thread: Kenmore Elite HE3 Dryer does not start
    Jul 2011
    Sterling MA
    Default Kenmore Elite HE3 Dryer does not start
    Model Number: 110.82822102
    I have a Kenmore Elite HE3 dryer model 110.82822102 purchased in 2003 that just stopped working. Pressing any cycle and holding down Start results in a single beep and then a click. I read some of the threads in this forum and found out how to get into Diagnostic Test Mode. When I enter diagnostic mode 88 shows as expected on the display and all the LEDs come on. Every button works except the Timed Dry cycle. Pressing it does nothing (no beep and the LED does not turn off). I also verified that in normal operating mode the Timed Dry cycle button does not work (the LED does not come on).
    Given those symptoms is it more likely to be the console electronics or machine electronics?
    Michael
    Hi Michael,
    Sounds like the user interface is bad.
    Your Kenmore is the exact identical to the Whirlpool Duet.
    WON’T START CYCLE
    WHEN START BUTTON
    IS PRESSED.
    1. If number display flashes, check to be sure the door is
    completely shut, and press and hold down Start for
    about 1 second.
    2. See TEST #2, page 3.
    3. See TEST #6, page 6.
    Here's the simplified diagnostics sheet(Page 7 tells how to take the bottom panel off) and the TEST #2 AND TEST #6:
    www.applianceblog.com/manuals/Tech_Sheet_8558722.pdf
    Here is the online repair manual for the Kenmore/Whirlpool Duet dryer:
    http://www.applianceblog.com/manuals/Duetdry.pdf
    Give it time to download. Page 6-3 is the trouble shooting section.
    It shows how to get access to the console panel keypad assembly on page 4-2 through 4-4 of the repair manual.
    Here's the control panel touchpad user interface(White) for your model:
    Manufacturer's Number: 8529879
    8529879
    Here's the graphite colored one:
    Manufacturer's Number: 8529881
    8529881
  1. FIXED: Kenmore Elite Dryer will not start up
    By DavidH in forum Sears Kenmore
    Last Post: October 14th, 2006, 01:34 AM
  2. Kenmore Elite dryer won't start
    By austinhoob in forum Sears Kenmore
    Last Post: May 19th, 2006, 08:59 PM
  3. Kenmore H3 elite elec. dryer won't start
    By andrewcu in forum Sears Kenmore
    Last Post: May 10th, 2006, 12:44 AM
  4. Kenmore Elite Dryer will not start
    By dragofamily in forum Sears Kenmore
    Last Post: April 11th, 2006, 01:10 AM
  5. Kenmore Elite Gas Dryer won't start 110.74952300
    By dogdaddy in forum Sears Kenmore
    Last Post: August 15th, 2005, 08:47 AM
