Results 1 to 10 of 17
Thread: Whirlpool washer WTW4800XQ0 lid won't stay locked
    Jan 2012
    Antioch, California, United States
    Default Whirlpool washer WTW4800XQ0 lid won't stay locked
    Model Number: WTW4800XQ0
    Our washer lid won't stay in the locked position after pressing the start button. The green fill light will come on, and a few clicks will happen like it is going to start the fill process and then red lock light goes off. I'very tried holding down the start button to reset, unplugging for a few minutes and retrying, but still it doesn't stay locked.
    Hi Patrick,
    This is a new Whirlpool Vertical Modular Washer.
    I have been researching this model online and the most common part to go bad with this issue your experiencing now is a bad lid lock switch.
    I located a service flash for this issue here: https://www.applianceblog.com/manuals/W10411107.pdf
    I was able to locate the repair manual for this model: https://www.applianceblog.com/manuals/W10329932.pdf
    Here's the lid lock switch for your model you can order here:
    Door Lock W10404050 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Watch this video:
    Jan 2012
    thanks. I'll give this a try and report back
    Ok, yes please do.
    Jan 2012
    Just a note of thanks. I got my part today. Installation took about 30 mins and was extremely easy. The lock stays lock now and we have clean clothes again.
    Excellent Patrick, glad to hear the new latch lock assembly fixed it.
    Jan 2012
    Well I spoke too soon. After the first load worked, we tried a second load. The washer displayed the same symptoms: A click of the lock engaging, the initial engaging of the drum drive (I assume this it what is happening), and then after a few seconds the lock light goes out. The green fill light stays on.
    I'm not sure this helped, but I turned the other control knobs and after resetting the lock a couple of times we were able to run a second load. After the second load we haven't been able to get another load to work
    Unplug the washer for 5 minutes, then try.
    If that doesn't resolve it read that manual there is a calibration section in there, you may need to recalibrate your washer.
    Jan 2012
    Howdy Jake. Finally had to wash some clothes today, so I tried to get into diagnostic mode to do the calibration you suggested. I could never get the mode. I then noticed that the manual link provided didn't cover my exact model as listed on the cover page. I wondered if the steps to get into the diagnostic mode on this model might be different than: Full Left - 1R - 1R - 1R - 1L -1R on the cycle knob.
    Good new though. After mucking with the knob and trying to start the washer, it did start.
    Yes, I noticed your exact model# was not covered in that manual, but that was the only manual I could locate that came close to your model.
    Ok, so now its working good?
  1. Replies: 6
    Last Post: January 13th, 2012, 02:00 PM
  2. Whirlpool range door locked
    By prg1066 in forum Whirlpool/Roper
    Last Post: May 16th, 2011, 12:59 AM
  3. Washer drum locked
    By rockinrodger in forum Sears Kenmore
    Last Post: October 2nd, 2009, 11:41 AM
  4. Whirlpool Duet Sport - door locked, need help
    By Ltunes in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 26th, 2007, 10:50 AM
  5. Kenmore HE4t Washer - Control Locked
    By zain in forum Sears Kenmore
    Last Post: September 17th, 2006, 07:28 AM
